Michael_Wu
(Michael Wu)
December 17, 2016, 2:48pm
1
I use at the Arlo security system. The problem is it doesn’t buffer anything so when it starts recording the motion could technically be gone already. So, What i would like to do is setup a motion sensor in a different place so when it detects I’ll tell the Arlo to start record ahead of the normal recording area. Problem is, I can’t seem to find a good outdoor motion sensor.
I have three st motions (gen 1) located outside, under eves. I can verify they work down to 25 degrees…
Michael_Wu:
The following thread should be of help
I am looking for outdoor motion sensors to monitor my yard.
I bought a pair of the Aeon Labs Aeotec Z-Wave Multi-Sensor and am quite unhappy with them. Even on the lowest sensitivity setting it randomly sends alerts, some perhaps due to clouds changing the lighting (even though PIR is not supposed to be susceptible to this) and others I can’t explain at all. With several false alerts a day this thing is just useless. The Smartthings Motion sensor works great, I have some in my house, but it is indoor rated only. The Schlage / Nexia motion sensor is also indoor use only.
I am hoping someone has come across an outdoor rated motion sensor they have been able to pair with the Smartthings hub.
