I made a feature request on the support forum for Android landscape support. I got a reply they have nothing in the works for it at this time. The Android app has a long ways to go so I can understand it isn’t a priority right now.
However, I was really looking forward to using a cheap wall mounted tablet as a control interface for SmartThings, so I started looking for a way to make landscape work. I didn’t have to look very long…there a lot of apps that can force landscape, like this one for example. https://play.google.com/store/apps/details?id=nl.fameit.rotate&hl=en
It works…but is far from ideal. You only get one row of tiles…but at least they are facing the right way.But, you could take it a step further and change the DPI in the build.prop to fit more on the screen. With a custom rom you can even do application independent DPI settings…man I love Android
tgauchat
#2
I still strongly believe that full “drag and drop” controls (widgets / gadgets) in the layout of the User’s choice is a preferable design.
Yes – this is definitely a departure from the current SmartThings GUI; but that’s all the more reason it would be useful for the entire API to be open to developers.
Heck … SmartThings elements should be logically convertible to RTI drop-able controls, in case one wishes to use RTI Panel as their default interface.
