Amazon Echo
As posted in another thread. The official announcement will be tomorrow AM.
It’s just like a movie trailer. Show some weird thing a pull it. Awesome marketing strategy ST! :smile:
That point is key. Using SmartThings and virtual devices you can do anything you want by actuating a virtual switch and having a SmartApp follow it. That means changing modes, executing Hello Home phrases (soon to be called Routines), or even controlling other web services.
I always forget about the big switch app. Also another great option if you don’t want to deal with custom device types and as long as you don’t mind a couple virtual switches in your setup.
Right … that’s how I’m doing a lot of stuff currently via the Hue Bridge Emulation method, which only accepts on/off and dim level.
how did you get dim level to work?? my setup only does on/off…
Is this integration controlled by Amazon? Sounds like Amazon has a baseline Home Automation control feature that ST will now be included in, which is great because you don’t need an intermediary step; but it also means that direct access of Hello Home and Modes probably won’t be coming since they aren’t universal to all home automation systems.
Thankfully as mentioned by several posters, ST’s flexibility provides for “workarounds” to make almost anything possible! Want to control your thermostat? Create a virtual dimmer and SmartApp to mirror its dim level to your thermostat!
Still, it provides room for @zpriddy’s excellent work that has Mode and Hello Home built in. It’s cool to say “Alexa, tell the house to say Good Night!”
Sounds like it will be the same as what we already have with the hue emulator hack, which will probably eventually go away anyway so this is great!
Also it will be one less hoop to jump thru. Once it’s native to SmartThings I’m sure the brilliant developers on this forum will do great things with it.
Way to go SmartThings!
Hopefully that is what the announcement will be tomorrow…or better :smile:
Scooby Doo voice: “oooohhh?”
I can see it…Alexa turn on “to 74 degrees” where “to 74 degrees” is a group in Alexa containing one on/off tile. I do that now with Wemo switches. “Alexa turn on Goodbye”, where Goodbye is a Wemo switch that also turns a virtual switch running the “Goodbye” phrase. Pretty rudimentary but works.
Even better - create a virtual dimmer named “thermostat” along with a SmartApp that just mirrors the dimmer setLevel over to your actual thermostat. Granted that will only work if a temperature range of anywhere between 1-100 degrees works for you :smile:
I am working on a thermostat dimmer switches app now. I already have an app that uses virtual switches to control mode and the autofan.
@mattfrank showed me his code to setup a thermostat dimmer switch. I am just modifying to it set a dimmer for heatingsetpoint and and a dimmer for coolingsetpoint in one app. Eventually I will merge this app with my other thermostat app.
@DarcRanger’s post is exactly what I meant by my quoted post above :smile:
I love this community!
The Amazon Echo/Akexa now shows SmartThings option under connected home above the Wink. The Smartathings side of things seem not to be active yet. We are close.
It’s NOW WORKING!!! BRAVO SmartThings, this is going to probably the best integration YET!!!
I was using the Hue Emulator bridge and this is more responsive in terms of timing as well.
Yup… working with native SmartThings connection! (… just as good as with Hue Bridge Emulator, though faster!) Having a little trouble with dimming requests, but I’m probably just speaking too softly this late at night.
Happy Alexa Day!
Dimming works for me. I am eager to try my virtual switches that control my Blinds or my garage doors (MyQ), but I cant wake up the 2 kids and wife now, otherwise Alexa will be murdered today!
Loading up on virtual switches for Hue color control #HappyAlexaDay
Working great and good deal faster than hue emulator method. Thanks SmartThings!!
What are the commands? I just linked it, but I’m at work. My wife is home and I was going to tell her to ask Alexa something. (She will, of course, be dubious)
