Finally received my hub (Kickstarter Backer) and have connected devices but there is no way of setting the parameters for Aeon Labs Micro Controllers, witch is something that I need as I use there micro switch and the lights won’t turn on when you press the switch due to the module being set to toggle and not momentary. This can all be set by the parameters of the micro controller as well as others that I would like to change ie overload protection.
LiquidChef
