the developer console shows service integrations that use the API now. Not sure when it was added but I was able to find why ST was messaging me about paying the upcoming monthly fee. It was an old Hubithing integration i installed 3 years ago to test. I have removed it so yippie!
The Developer Plan is currently available in the United States, Korea, Belgium, France, Germany, Italy, the Netherlands, Poland, and the United Kingdom. Availability may expand over time.
SmartThings API Plans for Developers and Businesses - Connected Services - SmartThings Developers
Yes. that appeared today. It should have been previously been visible using the CLI (smartthings apps) or in the /apps endpoint of the API.
UPDATE: It would appear that my receiving a 403 error on /smartapps may have been due to the nature of the PAT I was using, and had I used a different token I would have discovered that the new endpoint also handles Webhook apps, although the API Reference allows you to infer the contrary. I have removed the remainder of this post from view as it would be too misleading.
So, basically, if I want to directly call the API, not via CLI or AWA, I have to have a subscription? That seems to bear out as I’m getting
"error": { "code": "ForbiddenError", "message": "Not authorized",
for Postman calls that used to work.
My current best guess is that the subscription gives you access to the /smartapps endpoint of the API which is required to be able to create or update API Access apps. That’s pretty much it, if we ignore rate limits etc for the moment.
Update: It is probably less crude than that as using a different token avoids a 403 and reveals /smartapps is not exclusive to API Access apps.
The /smartapps endpoint has completely replaced the /apps endpoint in the API Reference, the Core SDK and the CLI.
The /apps endpoint has started returning 403 for me today. This means I can no longer manage my Webhook SmartApps via the API. While clearly it would be ridiculous if /apps could still manage API Access apps as it would bypass the subscription plan, this is a breaking change.
Update: It would appear my receiving a 403 on /smartapps is not the intention going forwards, but might be related to the particular PAT I was using. /smartapps returns Webhook SmartApps too.
I have not noticed any other changes in the API behaviour today, at least not on a read-only basis. I have an app that has a good poke around.
Hmm, well it’s working now for a simple GET on a device so perhaps a transient error.
So, if I understand what you are saying, any tool or service that simply pulls device information or issues commands to devices via the API should not be affected. So, things like the API Browser+ should keep working. It’s only the actual SmartApps that will require a subscription.
Yes, the target is specifically the API Access apps, also known as the API_ONLY apps, the OAuth-In apps, or more vaguely the OAuth2 apps. More specifically it is the ability to create and update the API objects that define them that requires the subscription.
However we shouldn’t forget that when the long lasting PATs were scrapped, a popular workaround was to create largely headless apps just to get renewable tokens to use instead of PATs. Anyone who took that path would have created API Access apps.
I would also suggest that we haven’t heard the last when it comes to restrictions on PATs. When they are mentioned things get very vague very quickly. So those community created tools that continue to use PATs should be fine as long as they steer clear of working with API Access apps, but I wouldn’t want to get too cosy with them.
There is also the issue of automations. Until recently Webhook and Lambda apps were the recommended solution for advanced automations that Rules could not handle, and before that they were also suggested for cloud devices. They weren’t really publicised but their basic usage was well documented. All of a sudden they seem to be disappearing without comment. What is the recommendation for advanced automations now? It is API Access apps.
Fyi
I guess times are tough even for samsung ??
Perfect timing - one more device and my migration to Home Assistant is complete. It was an interesting 11 years folks!
It seems that /smartapps returning a 403 could be related to my use of a long-lived PAT. Creating a PAT is far too tedious, but using my CLI token instead is certainly successful and also returns my Webhook SmartApps. I have therefore tweaked a couple of posts to either strike out or remove misleading comments.
So what is everyone doing about notifications specifically? I have been using both SharpTools and Pushover for more critical device alerts, and those are two obvious ones that go away with this change. I could always move these to Routines under each device, but I definitely prefer what I use now.
I’ve got Home Assistant running for other things, but the thought of moving my entire ST implementation over puts me off; I just don’t have the time right now.
If you only need to know whether the dishwasher is done, use a connected power meter and set an alert when power usage drops.
Out of curiosity, why do they go away with this change? Will your costs, if any, for using SharpTools increase significantly? How does Pushover get plumbed in?
IIRC, Pushover was a one time fee, and I don’t pay for SharpTools. The issue is that SharpTools uses the SmartThings API which is what is being moved to behind a paid subscription.
SharpTools pricing hasn’t changed as a result of this, but I introduced SmartThings API limits as a result of this and the premium tier has 10x the allowance. Since the SmartThings API calls cost me money, it’s hard to give away too much on the free tier!
Edit: It is only SmartThings API calls that count toward that allowance (eg. device actions, starting routines, etc). If the rule is triggered by a device event, that doesn’t count toward the allowance - there’s maybe an API call or two when the rule is first saved, but the ongoing event triggers don’t count.
Well, the other shoe dropped today. Got this email:
You’re receiving this email because you have a Personal Access Token (PAT) registered on your SmartThings account. We’re writing to let you know about upcoming changes that affect PATs.
What’s Changing
As part of our ongoing efforts to scale and maintain the SmartThings API, we are updating our legacy PAT policy.
- Expiration Date: Your PAT(s) will expire on December 15, 2026.
- Impact: Any scripts, personal dashboards, or third-party connections relying on this PAT will stop working after December 15, 2026, unless migrated to a paid supported API plan.
New Developer & Business Plans
PATs are intended for short-term development access to the SmartThings API. To support ongoing continued access to the SmartThings API, we recommend using OAuth through our SmartThings API Developer or Business plans.
On November 4, 2026, we released updated API plans for both business partners and individual developers.
Next Steps
To learn about how to continue operation of your integrations:
For Individual Developers: Visit the SmartThings Developer Center starting November 4, 2026 to sign up for the Developer Plan to maintain your current integrations and/or to build a new API Access App.
Availability for the individual Developer Plan: Note that the SmartThings API Developer Plan will be limited to certain countries upon launch. Country availability can be found in the FAQs on our SmartThings API page and in the Developer Center Console.
The December 15th date applies to all affected PATs including those owned by developers in countries where the Developer Plan is not available. If you have questions about your situation, contact developer support.
For Business Partners: To discuss pricing tailored to your usage, please contact us at partners@smartthings.com.
Plan details, pricing, and availability are subject to change.
For full details, please read our announcement on the SmartThings Blog. We will continue to share additional updates regarding token management policies as they become available.
Thank you for building with SmartThings.
Best regards,
The Samsung SmartThings Team
I just successfully moved my washing machine from using the SmartThings to the Home Assistant LocalThings integration.
That isn’t what is happening though. The paid subscriptions specifically address the use of API Access apps, which are typically used for integrating third-party services with SmartThings.
The Developer plan (the ~ £4.99/month plan) allows subscribers to create their own API Access apps in their own accounts and gives them a monthly allowance for API calls made by those apps. No subscription is required if you are only accessing someone else’s API Access app.
SharpTools is an API Access app, but it isn’t yours. On the other hand, if you install the SmartThings integration on Home Assistant that is again an API Access app and it is very much yours.
Yup. I got that e-mail, too. Grrr…
