This is the device type I am using: SmartSense Motion/Temp Sensor. If yours has a different name, go in IDE and switch the device type. You may need to reboot your hub for the change to take effect.
Here are directions received from support when they had to temporarily suspend my local processing:
here’s how you can switch the SmartApps back to running locally:
Log intohttps://graph.api.smartthings.com
Click ‘My Devices’
Click on your Motion Sensor
Click ‘Edit’ at the bottom
Click the ‘Type’ dropdown.
Scroll up and change the Type to ‘SmartSense Motion/Temp Sensor’ (the list is in alphabetical order)
Click ‘Update’
Then, press the red button on the back of the Hub to reboot it, and that should get the apps running locally again.
You can double check by going to this link:
https://graph.api.smartthings.com/localInstalledSmartApp/list
