I get the dreaded 500 error when trying the auth workflow to get an access token.
Is there any way to get the actual stack trace to see what I am doing wrong? Do you see anything wrong/missing from the request?
Thanks for your time.
I suspect they may do some rate limiting on auth calls. Anyway, I also start getting 500’s when testing my app once in a while.
Thanks @geko
This has been happening for two days now. Do you see anything wrong with the request?
Actually, you also have to include redirect_uri in your request.
I did earlier with same results, but I thought of removing it for calling from Postman
Can someone from smartthings look into the logs based on the reference code or comment on what could be wrong here?
Hi @geko! Sorry to bother you again but you are the only one seem to be responding (and thanks for that
I see that I am logged in because “My Devices” etc links show up in the response, but I was expecting a token in a JSON response, which is not part of it. Also the response is in html. Any thoughts?
I was using my friend’s credentials who I gave access to my account. These errors can certainly use some finesse.
Old thread but having the same problem. Support was unable to give my any suggestion other than trying here. This is the latest thread I could find, and I’ve read most of them.
I can get the code, makes me sign in and authorize then redirect back to the initiating program and attempt to get the token, without success using GitHub - adoy/PHP-OAuth2: Light PHP wrapper for the OAuth 2.0 protocol (based on OAuth 2.0 Authorization Protocol draft-ietf-oauth-v2-15)
Any suggestions or working PHP example appreciated.
Here is a snippet of the PHP code
const TOKEN_ENDPOINT = 'https://graph.api.smartthings.com/oauth/token'; $params = array('code' => $_GET['code'], 'redirect_uri' => REDIRECT_URI, 'scope'=>'app'); $response = $client->getAccessToken(TOKEN_ENDPOINT, 'authorization_code', $params);
the getAccessToken function adds the proper header, Client_id, and Client_Secret. Same result with or without the scope=app param
Oh No! Something Went Wrong!
Error
500: Internal Server Error
URI
/oauth/token
Reference Id
2ded8225-8e6f-4752-8ff0-a07d33032c04
Date
Tue May 15 18:00:14 UTC 2018
Just fixed it!
Changed connection points
from
to
https://graph-na04-useast2.api.smartthings.com
