Is there any way to determine the location (what hub) a device ID is connected to? It doesn’t seem to be part of the device class.
def hubIp = device.hub.getDataValue("name")
a-ha, thank you very much.
In this function, I can’t seem to get the hub info - any ideas?
private deviceItem(it) {
def hubinfo = it.hub.getDataValue("name")
it ? [id: it.id, label: it.displayName, hub: hubinfo] : null
This is the code I’m using to call that function (part of the API I am building)
def type = params.deviceType
settings[type]?.collect{deviceItem(it)} ?: []
@geko any ideas? thanks!
An update - figured it out, I was able to simply say device.hub.id / device.hub.name…
Now only if I could get the deviceTypeId…
