The_papy
(deldime)
March 27, 2024, 4:31pm
1
plz help, how to upgrade maybe the driver Aeotec hub, or how to detect Open door sensor from aqara T1 ?
impossible to pairing i have pairing with succes sensor aqara temperature and humidity
Cheers
smarthinks , search open / close windows doors , impossible to pairing
TapioX
March 27, 2024, 5:12pm
2
Aqara door sensor is in ST official (production) driver.
deviceLabel: Aqara Door and Window Sensor T1
manufacturer: LUMI
model: lumi.magnet.agl02
deviceProfileName: contact-battery-profile
Aeotec Hub loads driver automatically.
Sensor have to be very near the hub when you make pairing.
Aeotec also provides manufacturer specific drivers here .
The_papy
(deldime)
March 28, 2024, 10:09am
4
Sorry work when you choice Aotec and not aqara ! For pairing…
Last question
I use aqara sensor t1 we’re is air pressure ?? In SmartThings ?
Cheers
The_papy
(deldime)
March 28, 2024, 10:10am
5
I see only temperature and humidity… no air pressure,
I use aotec hub
Cheers
The aqara door sensor detects
Open/close
Temperature
Humidity
It does not detect air pressure, regardless of the hub you use it with.
Aqara has a different device, the square one, which detects
Temperature
Humidity
Air Pressure
Which one are you asking about?
The_papy
(deldime)
March 28, 2024, 3:28pm
7
'utilise le capteur aqara t1 , j’ai précisé ,) merci , est-ce possible d’optenir également la pression atmosphérique ?
You should ask aqara. The specifications for that device do not list air pressure measurement as one of its features.
