I just purchased the Z-Wave Toolbox, but seem to be missing a (probably simple) step to get it working.
I will provide a brief overview of my home network to clarify a few of my issues.
My home network is an internal 192.168.1.x network created by my ASUS router, connected to an Arris cable modem. Oddly enough, my cable modem is accessible from a web browser at 192.168.100.1 (a different subnet, and coincidentally the same default IP address used by the Z-Wave Toolbox).
So, when I installed the Z-Wave Toolbox (wired Ethernet), I decided to change its IP from 192.168.100.1 to 192.168.100.2 (just to be safe, even though it appears that this is a WiFi-only IP address?). In any event, I am able to access the Z-Wave Toolbox web interface, both by typing in z-wavetoolbox[6-digit serial].local into a web browser, or by connecting to it via WiFi and then typing in 192.168.100.2 into the web browser.
So, that part works fine, though at this point it doesnt seem to be able to see my SmartThings Hub (on the 192.168.1.x subnet) or any of my z-wave devices on my hub. My router does not appear to be aware of the Z-Wave Toolbox, though I can access it via my web browser.
So, my confusion appears to stem from the use of a separate “monitoring” device, which I assume could be a laptop. Since my desktop machine (an iMac) is very close to the SmartThings hub (less than 30 feet away), and has both wired Ethernet and WiFi connectivity, I am wondering if I can use the WiFi connection as the monitoring device.
In either event (whether using a laptop or the WiFi connection on my desktop), I dont know how to “connect” the Z-Wave Toolbox (at 192.168.100.2) to see my SmartThings Hub (which is on my 192.168.1.x subnet). I’m guessing this is a smple step, but I dont know how these 2 different subnets can connect (since I hope/assume I dont need to change the SmartThings Hub to a different subnet - eg, 192.168.100.x).
Could definitely use a little help here.
PS
I also have one related question once this is up and running (possibly relating to the Packet Analyzer feature).
Will the Z-Wave Toolbox enable me to see the dynamic path used by a device when it sends a message to another device? For example, if Device A sends a message to Device D (eg, one light switch turning on another light switch when it is pressed), the path might be from Device A to Device B to Hub to Device C to Device D. Is that something the Z-Wave Toolbox can “monitor” (like an IP traceroute), even though the Z-Wave Toolbox is not part of that entire path?
