Since one of the last outages I’ve been having an issue with one of my Jasco Zwave Plus switches. It appears “offline” but still responds (sometimes with a bit of a delay).
Every time I try a zwave repair I get could not delete old routes, and could not assign new route.
Nothing has moved or changed, no new devices added or removed. I feel like this has happened before and usually resolves itself after a day or to. But being this is an outdoor light and I use heavily in automation, it’s kinda annoying.
@scoob8000 This has happened to me before with tasmota plug sockets. I recommend you cut power to the switch for 60 seconds (trip the circuit breaker). This works for me with my tasmota plugs. Smartthings basically fails to see that a device has gone back online.
Until you fix that Zwave mesh issue, that’s going to continue I’m afraid. Are there any nearby repeaters? Have you tried to exclude / re-add? (yes I know, painful, especially with the fact that excluding will delete automations this switch is in.)
And magically after a day or two, this device is working normally again. I tried flipping the breaker, repair, rebooting hub, nothing worked. I was reluctant to remove and re-add the device since this has happened before and fixed itself.
The past time or two it’s happened (different devices) was after an ST outage of some sorts.
