In their docs they say it just uses multi channel command encapsulation of commands such as Switch Binary, Meter, and Basic. They say they use COMMAND_CLASS_MULTI_CHANNEL_V2, which I don’t even have in my Z-Wave docs (?)
The parameters aren’t quite right for the V3 encapsulation command above, try this:
Still no luck… I’ve played around with your code @duncan and it doesn’t seem to help. Not sure if I’m doing everything right though.
Do you guys have one at SmartThings to test with? If not I’d be happy to loan you mine for testing/typing purposes. I don’t have a use for it right now until we can get the 4 outlets to work independently. Just let me know.
Okay… so Apparently I lied. Just for the fun of it I tried the Device Type Simulator with the AEON Power Strip type that I created based on your work @bigpunk6. When I did that and clicked the on1, off1, on2, etc buttons, they worked!! Because I’m tried different codes offered here, I’m not sure whose this was, but this is the code for the individual commands:
So, what I discovered is that the on/off commands work in apps and in the simulator, but not in the mobile app. The tile “buttons” don’t work, but as I said, it does work in apps.
Now, I suggested earlier in this thread that the best was to use this would be to “bind” each of these outlets to a virtual on/off tile because the virtual on/off tiles can be used in any problem that a switch without needing to re-write the app.
So, I’ve written up a app that allows you to do this. Asks for the power strip and 4 other switches to bind to the 4 outlets. Simply watches for the virtual switches turn on or off, and turns on or off the corresponding outlet on the strip.
What’s the license on your Device Type? I’d like to share what I’ve got for the AEON power strip Device Type, but honestly, it’s 92% your work… through in 4% of Help from Duncan and then the rest is just me snipping out parts I didn’t need and/or minor modifications so before I share it with anyone, I want to make sure I’m respecting your work.
Heck, for that matter… seeing is it’s almost completely yours I’ll just send you my modifications and you can share it on your github if you want.
Regarding the tiles not working, did you change the tile definitions after trying the SmartApp on your phone the first time? I’ve had problems before with the iOS app caching device types and continuing to use the old tile commands until I sign out and back in.
Is there a way to send a raw zwave command to a device from device type code?
Something like “zw device: 0C, command: 2501, payload: FF” or 0C2501FF?
Also what is Commands Raw used for in the IDE? Everything i tried in there yielded zero results. I understand how to send raw Messages but cant figure out the Commands side.
Okay, after some more testing I discovered that the tiles do work… kinda. Here’s the thing: The tiles never update in the mobile app.
If I have Switch1 physically on and then I tap the Switch1 tile, it will physically turn off the outlet, but the tile still say that it’s on. Tapping the tile again just continues to send the off1 command.
The only way that I’ve discovered to turn off the tiles is to use the IDE simulator on the power strip and hit the switch off button. This will turn all the tiles off, even if the outlets are on. Now if my outlet is off and my tile is off if I tap the tile it will turn on the outlet. But again, the tile does not update. It still thinks the outlet is off. Tapping on the tile will just repeatedly send the on1 (or on2, etc) command.
YOu might be having a problem that I was having a while back. Just a suggestion but try try renaming the “on” “off” commands to something like this:
state “on”, label:’${name}’, action:“switchOff”, icon:“st.switches.switch.on”, backgroundColor:"#79b821"
state “off”, label:’${name}’, action:“switchOn”, icon:“st.switches.switch.off”, backgroundColor:"#ffffff"
then rename the methods below in your device file to match as well as adding the custom commands to the device in the IDE page. There’s something in the ST helper code that messed with my virtual devices and this was able to get around it.
If you can toggle the switch then the commands are configured correctly but if the tile does not update then something is wrong with the Custom Attributes. You have to add the Custom Attributes to the device type settings just like the custom commands. If you changed them from switch1 - switch5 then you need to change the Custom Attributes.
Also did you try to refresh after toggling the switch?
