@jwu
amended the device handler as suggested (amended code is copied in the end). on1-3,off1-3 work, on refresh tiles for power/energy/power1/energy1 get updated latter ones with lesser value, though power1/energy1 should have same data as main tiles as endpoint1 should give combined data.
… No debug messages are printed though from zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd)
Manual for the device is here:
http://www.z-wave.ru/podderzhka/skachat/category/82-tkbhome.html?download=200:tz04-manual
changed code:
* Aeon Smartstrip
// for the UI
metadata {
simulator {
// TODO: define status and reply messages here
tiles {
valueTile("power", "device.power", decoration: "flat") {
state "default", label:'${currentValue} W'
valueTile("energy", "device.energy", decoration: "flat") {
state "default", label:'${currentValue} kWh'
standardTile("switch1", "device.switch1",canChangeIcon: true) {
state "on", label: "switch1", action: "off1", icon: "st.switches.switch.on", backgroundColor: "#79b821"
state "off", label: "switch1", action: "on1", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
standardTile("switch2", "device.switch2",canChangeIcon: true) {
state "on", label: "switch2", action: "off2", icon: "st.switches.switch.on", backgroundColor: "#79b821"
state "off", label: "switch2", action: "on2", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
standardTile("switch3", "device.switch3",canChangeIcon: true) {
state "on", label: "switch3", action: "off3", icon: "st.switches.switch.on", backgroundColor: "#79b821"
state "off", label: "switch3", action:"on3", icon: "st.switches.switch.off", backgroundColor: "#ffffff"
standardTile("refresh", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:"", action:"refresh", icon:"st.secondary.refresh"
standardTile("reset", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:"reset kWh", action:"reset"
standardTile("configure", "device.switch", inactiveLabel: false, decoration: "flat") {
state "default", label:"", action:"configure", icon:"st.secondary.configure"
valueTile("power1", "device.power1", decoration: "flat") {
valueTile("energy1", "device.energy1", decoration: "flat") {
valueTile("power2", "device.power2", decoration: "flat") {
valueTile("energy2", "device.energy2", decoration: "flat") {
valueTile("power3", "zwaveEvent(cmd.sourceEndPoint, zwave.parse(desc, [ 0x60:3, 0x25:1, 0x32:1, 0x70:1 ]))device.power3", decoration: "flat") {
valueTile("energy3", "device.energy3", decoration: "flat") {
main(["switch1", "power", "energy"])
details(["power", "energy", "reset", "switch1","switch2","switch3","refresh","configure",
"power1", "energy1","power2", "energy2","power3", "energy3"])
// 0x25 0x32 0x27 0x70 0x85 0x72 0x86 0x60 0xEF 0x82
// 0x25: switch binary
// 0x32: meter
// 0x27: switch all
// 0x70: configuration
// 0x85: association
// 0x86: version
// 0x60: multi-channel
// 0xEF: mark
// 0x82: hail
// parse events into attributes
log.debug "Parsing desc => '${description}'"
def result = null
def cmd = zwave.parse(description, [0x60:3, 0x25:1, 0x32:1, 0x70:1])
if (cmd) {
result = createEvent(zwaveEvent(cmd))
log.debug "Parsing result => '${result}'"
return result
//Reports
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "physical"]
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
[name: "switch", value: cmd.value ? "on" : "off", type: "digital"]
def zwaveEvent(physicalgraph.zwave.commands.meterv1.MeterReport cmd) {
def map = []
if (cmd.scale == 0) {
map = [ name: "energy", value: cmd.scaledMeterValue, unit: "kWh" ]
else if (cmd.scale == 2) {
map = [ name: "power", value: Math.round(cmd.scaledMeterValue), unit: "W" ]
map
def zwaveEvent(int endPoint, physicalgraph.zwave.commands.meterv1.MeterReport cmd) {
// MeterReport(deltaTime: 1368, meterType: 1, meterValue: [0, 3, 29, 17], precision: 3, previousMeterValue: [0, 3, 29, 17], rateType: 1, reserved02: false, scale: 0, scaledMeterValue: 204.049, scaledPreviousMeterValue: 204.049, size: 4)
log.debug "EndPoint $endPoint, MeterReport $cmd"
def map = []
map = [ name: "energy" + endPoint, value: cmd.scaledMeterValue, unit: "kWh" ]
map = [ name: "power" + endPoint, value: Math.round(cmd.scaledMeterValue), unit: "W" ]
map
def zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelCmdEncap cmd) {
log.debug "MultiChannelCmdEncap $cmd"
def map = [ name: "switch$cmd.sourceEndPoint" ]
if (cmd.commandClass == 37){
if (cmd.parameter == [0]) {
map.value = "off"
if (cmd.parameter == [255]) {
map.value = "on"
map
else if (cmd.commandClass == 50) {
// bitAddress: false, command: 2, commandClass: 50, destinationEndPoint: 1, parameter: [33, 100, 0, 0, 0, 0, 0, 94, 0, 0, 0, 0], res01: false, sourceEndPoint: 1
def hex1 = { n -> String.format("%02X", n) }
def desc = "command: ${hex1(cmd.commandClass)}${hex1(cmd.command)}, payload: " + cmd.parameter.collect{hex1(it)}.join(" ")
// Re-assign source end point 3-6 to 1-4 and 1-2 to 5-6 to sync up with the switch end points.
// Source end point in the message refers to always-on sockets.
zwaveEvent((cmd.sourceEndPoint > 3) ? (cmd.sourceEndPoint-3) : (cmd.sourceEndPoint+3), zwave.parse(desc, [ 0x60:3, 0x25:1, 0x32:1, 0x70:1 ]))
map.value = "off"
map.value = "on"
map
def zwaveEvent(physicalgraph.zwave.commands.multichannelv3.MultiChannelCapabilityReport cmd) {
// [50, 37, 32], dynamic: false, endPoint: 1, genericDeviceClass: 16, specificDeviceClass: 1)
log.debug "multichannelv3.MultiChannelCapabilityReport $cmd"
def zwaveEvent(physicalgraph.zwave.commands.configurationv1.ConfigurationReport cmd) {
log.debug "Configuration Report for parameter ${cmd.parameterNumber}: Value is ${cmd.configurationValue}, Size is ${cmd.size}"
def zwaveEvent(physicalgraph.zwave.Command cmd) {
// Handles all Z-Wave commands we aren't interested in
log.debug "Capture All $cmd"
// handle commands
def refresh() {
def cmds = []
for ( i in 1..3 )
cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:i, commandClass:37, command:2).format()
for ( i in 1..3 ) {
cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:i, commandClass:50, command:1, parameter:[0]).format()
cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:i, commandClass:50, command:1, parameter:[16]).format()
cmds << zwave.meterV2.meterGet(scale:0).format()
cmds << zwave.meterV2.meterGet(scale:2).format()
delayBetween(cmds)
def on(value) {
log.debug "value $value"
delayBetween([
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint: value, commandClass:37, command:1, parameter:[255]).format(),
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint: value, commandClass:37, command:2).format()
def off(value) {
delayBetween([
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint: value, commandClass:37, command:1, parameter:[0]).format(),
def poll() {
refresh()
def configure() {
log.debug "Executing 'configure'"
delayBetween([
zwave.configurationV1.configurationSet(parameterNumber:101, size:4, configurationValue: [ 0, 0, 127, 127 ]).format(), // Report meter on all channels (6 sockets + master)
zwave.configurationV1.configurationSet(parameterNumber:111, size:4, scaledConfigurationValue: 120).format(), // 120s interval for meter reports
zwave.configurationV1.configurationSet(parameterNumber:4, configurationValue: [0]).format() // Report reguarly
def on1() {
delayBetween([
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:1, parameter:[255]).format(),
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:2).format()
def off1() {
delayBetween([
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:37, command:1, parameter:[0]).format(),
def on2() {
delayBetween([
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:2, commandClass:37, command:1, parameter:[255]).format(),
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:2, commandClass:37, command:2).format()
def off2() {
delayBetween([
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:2, commandClass:37, command:1, parameter:[0]).format(),
def on3() {
delayBetween([
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:3, commandClass:37, command:1, parameter:[255]).format(),
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:3, commandClass:37, command:2).format()
def off3() {
delayBetween([
zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:3, commandClass:37, command:1, parameter:[0]).format(),
//test
def test() {
def cmds = []
// cmds << zwave.multiChannelV3.multiChannelCapabilityGet(endPoint:1).format()
// cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:3, commandClass:50, command:1, parameter:[0]).format()
// cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:3, commandClass:50, command:1, parameter:[16]).format()
// cmds << zwave.multiChannelV3.multiChannelEndPointFind(genericDeviceClass:32).format()
// cmds << zwave.multiChannelV3.multiChannelEndPointGet().format()
// cmds << zwave.meterV2.meterGet(scale:0).format()
// cmds << zwave.meterV2.meterGet(scale:2).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber:101).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber:4).format()
cmds << zwave.configurationV1.configurationGet(parameterNumber:90).format()
log.debug "Sending ${cmds.inspect()}"
delayBetween(cmds, 2300)
def testA() {
log.debug "testA"
def cmds = []
cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:50, command:1, parameter:[0]).format()
cmds << zwave.multiChannelV3.multiChannelCmdEncap(sourceEndPoint:1, destinationEndPoint:1, commandClass:50, command:1, parameter:[16]).format()
delayBetween(cmds, 1000)
//reset
def reset() {
def cmds = []
cmds << zwave.meterV2.meterReset().format()
for ( i in 1..6 )
delayBetween(cmds)
