I rarely use the garage lights. Installed the zwave switch to control the lighting when i am away. Lighting on a timer etc etc
I do have an extra Zwave switch I can swapout to see if the same thing occurs. Just thought I would ask here in the forum with you experienced advanced users prior.
Further testing of the Status Update of the switch
Yes the Switch Turns On or Off on the First Press however the Status will not update.
Status of the switch will update on the 2nd press
If switch is left only on the 1st press. The status of the switch will update itself 10-15 minutes later
In Classic App I can press the REFRESH tab in the switch and the status will immediately update
I have pulled out the Air Gap tab on the Jasco GE Enbrighten switch for 24 hours to see if anything changes. No changes occur and the switch operates as indicated above
Can anyone give any insight why this switch does this?
All my other switches are the same make and model and they operate perfectly with the status of the switch if On or Off
