All devices that are near to hub work fine but those that should rely on the other switches to act as repeaters do not work
I am able to include all the nearby one with keeping the hub at its permanent locationi
For the ones that are further I had to bring hub closer but after I moved hub to its permanent location the ones that are further can no longer be controlled
Some of them are just 15 ft away of the nearest working switch with nothing but air in between
Intermatic Z-wave devices have notoriously poor range. I’d try repairing your network again. If that doesn’t work, I’d consider adding a couple of newer devices into the mix.
With all your devices in their final location, try repairing the network several times. Check the logs and look for any errors. Finally, try rebooting the hub.
I find checking the logs is mostly useless for zwave network issues. It’s unlikely to turn up something you can actually control/fix without contacting support anyway. That, or you probably already know what the problem is, something like a device being out of range and you merely use the log to confirm this.
