I have installed the ZRTSI and it has been integrated into my ST hub as dimmer switches. I was hoping that because it is a dimmer, it can technically stop anywhere between 0 and 100, however, it only does open or close and nothing in between. How do I change this such that if I have a scene that requires the shades to be open 10%, that only 10% is opened and not 100%.
the ZRTSII can only go to open, close and preset positions.
So while there is a dimmer device, you are forced into on, off, or 50% (meaning preset).
You have to have preset programmed into your shades in and the location of preset is how the shades were programmed (mine were 1/2 open), but this can be adjusted using your tells remote.
So ZRTS II is “basic”…
Thank you. Once the favorite is programmed using the Tells remote, how does that favorite get executed in ST?
