Updated device handler, fixed the battery value shown.
Previously it used to show 255% when it was about to die, now it shows 1%, it now updates the battery level once a day.
I’ve been getting about 2-3 months life out of the batteries on my 3 devices, my Enerwave motion sensors (which don’t have temp, humidity or illumination are still running on their first set 8 months after install.
To help with this I’ve changed the wakeup interval default to 60 mins (from 30) and dialed back the temp alerts to only happen when the temp changes a whole degree C rather than 0.1 degrees C. Hopefully this will improve the battery life. If you already installed this device handler you’ll need to goto the setting and change the values yourself in the device settings.
The updated device handler code is in the 1st post of this thread.
