I recently purchased about 15 Zooz ZEN21 switches and have installed about 10 of them. I have installed the custom DTH and most of the switches installed fine. However, a few showed up as Z-Wave Switch instead of grabbing the DTH for the Zooz switch. I went into IDE and just manually changed the DTH to the Zooz switch and everything appears to work fine with the switch but the Raw Description field seems blank/short/incomplete.
Here are a couple of comparisons:
Switch that paired perfectly:
zw:L type:1001 mfr:027A prod:B111 model:1E1C ver:3.03 zwv:5.03 lib:03 cc:5E,25,85,8E,59,55,86,72,5A,73,70,5B,6C,9F,7A role:05 ff:8700 ui:8704
Switch that paired as Z-wave Switch and I had to manually change the DTH:
zw:L type:5E25 mfr:0000 prod:0000 model:0000 ver:3.03 zwv:5.03 lib:03
Third comparison that’s missing the role, ff, and ui fields for some reason:
Is this all not a big deal or will this have any type of effect that they are all different? Again these are all the same switches and appear to all be working fine.
