I thought maybe my z-wave network was weak and that was why my Zooz sensors were not working. I have updated the sensors with the Rboy device handler and I did not see anything different. I added two Dome z-wave range extenders and did a z-wave repair and I did not see any results. I hit the wakeup button today just to verify I did everything I could think of and I am still not seeing any data. I realized later that the Dome’s were not necessary as my Zooz sensor is next to a GE in-wall switch (which is z-wave plus). Any ideas on what I could do? I added a couple photos for additional details.
Try to have a hard reset. I recently had to do it as even after replacing the batteries, the sensor would not refresh. Since then they work ok
We also recommend waking the sensor up manually by clicking the Z-Wave button with a paperclip so it can finalize configuration.
Press the update button at the bottom of the sensor with a pin (through the hole). If that doesn’t work, do a factory reset.
I already tried the wake up sensor as suggested, but I will try to do another factory reset to see if there is an improvement (I started with that last week). I will report back with results.
Okay, I had to do a couple factory resets (pressing button with included paperclip 10x) but it worked. In the past just pressing the wake up button once did not do anything. This time if I pressed the wake up button twice then all the data @RBoy programmed populated. Whew!! Thanks for the guidance. I will post again if the devices drop off, but I am feeling confident that this time everything is ready to go.
A reset a day keeps the sensor awake…
Okay, about week in and I have sensor that works and one that does not. The sensor that is not working I have to wake up everyday. Each day I get the same data temp of 72.2, 0 lux, 64% humidity after the wake up but nothing afterwards. I did another factory reset today without any different results. The sensor still does not update and I get the same data results (which are not accurate). Do you guys have any other ideas that I could try or was this just a bad sensor?
I just got one replaced that was acting pretty much like that. It would wake up with the manual reset and report the exact same wrong measurements every time. I sent it back for testing and it gave them the very same numbers when they reset it. It worked fine until the battery died and I had to replace it.
I’ve been trying to factory reset the 4in1 sensor for days. Doesn’t seem to be working. I’m not getting the 4 or 5 blinks after the reset.
This is quite an old thread, but the same thing that is happening to @Snipe3000 is happening to me. I am trying to factory reset it, but it’s not behaving as explained. Mine are the 700 Series.
