tonykeyser
(tonykeyser@yahoo.com)
October 6, 2016, 1:01pm
1
Anybody managed to integrate a Zipato Z-Wave to IR Extender with their ST ecosystem? The documentation at the link below seems to be pretty comprehensive. I would like to know if this would work as a solution to control my Projector (LG) and soundbar (also LG).
CSC
October 6, 2016, 1:17pm
2
It’s a rebranded device, see this, same device.
Hi @Ron Thanks for making this DTH.
I have an issue with setting the temp.
I have learned the IR codes from my original remote, and Im using config code 000. And Im using the latest version of your improved DTH. But when I try to send a select a temp and heat/cool the temp reported back from the zxt-120 is not the same.
Here is an example:
I select 22 deg celcius and then heat, this is from the logs:
a7dbfb9e-ddf8-4a7a-9c59-0defb74f96c8 20.42.32 CEST: debug Thermostat Setpoint Report for reportedHeatingSetpoint = 21 forcing state change true
a7dbfb9e-ddf8-4a7a-9c59-0defb74f96c8 20.42.32 CEST: info RRG V1 ThermostatSetpointReport cmd=ThermostatSetpointReport(precision: 0, reserved01: 0, scale: 0, scaledValue: 21, setpointType: 1, size: 1, value: [21])
a7dbfb9e-ddf8-4a7a-9c59-0defb7…
