Adyku
(Adyku)
September 15, 2017, 4:06pm
1
Hello,
Please give me your feedback for the next DTH.
* Copyright 2015 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
* Zipato Combustible Gas Detector
* Author: Adrian Mare
* Date: 2017-09-15
metadata {
definition (name: "Zipato Combustible Gas Detector", namespace: "SmartThingsRO", author: "Adrian Mare") {
capability "Health Check"
This file has been truncated. show original
Thank you
jimm87
December 15, 2017, 7:16pm
2
Hey there thanks for writing this! It seems to me that the device monitoring is not working for some reason. I have two devices both located close to the hub but periodically they both say device unavailable. One of them seeems to correct periodically but not for long - eventually it shows as device unavailable again. Any ideas?
What happened to this project for the Zipato Smart Combustible Gas Sensor? Zigbee or Zwave?
Halideco2
(Steven Flores)
February 22, 2018, 9:44pm
4
Hi Adyku,
The github link appears to be offline. Could you restore it? Thanks
Adyku
(Adyku)
February 25, 2018, 2:13pm
5
Problems fixed. Let me know if anything goes wrong.
Enjoy!
jimm87
April 3, 2018, 9:12pm
6
Hi Adyku - installed the latest version but still getting device not detected when device monitoring is turned on?
jinaths
(Jinath)
July 12, 2018, 1:48pm
7
I know a lot of time has passed since anyone posted here, but for anyone still having this problem, please see this link:
Ok - so for any of you who might have the same problem I have, please refer to this link:
This page has the correct DTH for this device. I changed the code slightly so that it had my device’s fingerprint, which is a little different to the one in the code. You can find this in the Raw Description of the device.
Steps to install:
Include normally, let the system find it - it will be included as a Z-Wave Sensor, then get the fingerprint (mfr) from the Raw Description of the device in the Smartthings IDE.
Exclude it from the system again, edit the mfr in the code to be the same as that of the device you have. Save the code.
Re-include the device, same procedure, except now it will be detected as a “Combustible Gas Sensor”.
Go to the IDE again, change the DTH back to Z-Wave…
Hope it helps.
