After the firmware update 000.018.00018 my Zipato Alarm has stopped working. To be more precise the Antitamper still sounds the alarm - when removing it from the wall.
The alarm appears to be ONLINE from the device menu on the portal.
However all attempt to sound the alarm or make a beep from the “Things Controller” or from code that had been working for months fails to work.
I even purchased a second alarm - it paired to the hub without problem but again it behaves identically to the first.
I have rebooted the hub several times.
I dont know it has anything to do with the firmware update but it seemed to stopped working at the same time.
I am using the Kevin LaFramboise 1.5.6 Driver
Hi,
Happy to help out, But need some more guidance… to get the data
When I switch back to using their driver 1.5.6
I go to live logging on the smartthings web portal
When I use the tablet app on the siren thing - I press beep or siren.
It gives the usual message like playing sound 1 but nothing else.
What and how would you like me to collect additional log data…?
Open the device from the Mobile App and go into the settings.
Enable the “Enable debug logging” setting and tap Done.
Tap the beep tile and wait 5-10 seconds to see if it makes noise
Tap the siren tile and wait 5-10 seconds to see if it makes noise.
On the live logging page, click your siren name so that only the log entries for that device are shown. (The device name should be listed above the log entries).
Not sure If this helps but the siren still works properly if you use the basic aeon siren device handler but this only has basic alarm on / off capability. it has no beep command.
I have tested 1.5.7 from the Tile application and I confirm it seems to be fully working.
What changed with the firmware update if you dont mind sharing?
Here is the log details you asked for:
c40a3578-1e60-4596-9791-ffd02d0061a4 9:14:01 AM: debug Zipato Multisound Siren turned off
c40a3578-1e60-4596-9791-ffd02d0061a4 9:13:59 AM: debug Zipato Multisound Siren turned on
c40a3578-1e60-4596-9791-ffd02d0061a4 9:13:59 AM: info Playing Sound #1
c40a3578-1e60-4596-9791-ffd02d0061a4 9:13:57 AM: debug Zipato Multisound Siren turned off
c40a3578-1e60-4596-9791-ffd02d0061a4 9:13:51 AM: debug Device Checked In
c40a3578-1e60-4596-9791-ffd02d0061a4 9:13:51 AM: debug Zipato Multisound Siren turned on
c40a3578-1e60-4596-9791-ffd02d0061a4 9:13:50 AM: info Playing Sound #1
c40a3578-1e60-4596-9791-ffd02d0061a4 9:12:04 AM: debug Device Checked In
c40a3578-1e60-4596-9791-ffd02d0061a4 9:12:04 AM: debug Zipato Multisound Siren turned off
c40a3578-1e60-4596-9791-ffd02d0061a4 9:12:04 AM: debug Zipato Multisound Siren turned on
c40a3578-1e60-4596-9791-ffd02d0061a4 9:12:01 AM: info Playing sound #6 0 time(s)
c40a3578-1e60-4596-9791-ffd02d0061a4 9:12:01 AM: debug Zipato Multisound Siren turned off
c40a3578-1e60-4596-9791-ffd02d0061a4 9:11:59 AM: debug Notification Type: Notification Report
c40a3578-1e60-4596-9791-ffd02d0061a4 9:11:57 AM: debug Alarm State: enabled
c40a3578-1e60-4596-9791-ffd02d0061a4 9:11:54 AM: debug Alarm Duration: 180 Seconds
c40a3578-1e60-4596-9791-ffd02d0061a4 9:11:53 AM: debug
Strobe Sound: Emergency
Siren Sound: Emergency
Both Sound: Emergency
On Sound: Emergency
Beep Sound: Beep
