I’m trying to figure out how a Zigbee Network maintains its health. My situation is Smarthings Hub V2, numerous Smartthing Devices, Sonoff Devices, Tradfi Repeaters.
I have a few Sonoff devices(SNZB-02, 04)keep going offline. In troubleshooting I keep looking at Device Route. Sometimes it shows via the repeaters and this am it was offline again. Looked at the Route and the device was direct to the hub. Found this odd as the nearby repeaters were all online.
My question is how do I troubleshoot? Do Zigbee Networks continue to change the route on its own?
WiFi Channel 9 and Zigbee Channel 20 are right on top of each other, so very not good.
In addition, Wi-Fi channel 9 is not one of WiFi’s three nonoverlapping channels, many Wi-Fi routers won’t even give you that choice. Typically you have a choice between Wi-Fi channel 1, 6, and 11. If you were previously forced to choose Wi-Fi channel 9 because of other network interference issues, then you’ll need to find out the specifics of those as they might be an issue for zigbee as well.
The easiest choice to avoid zigbee/Wi-Fi interference would be to use channel 11 for both of those, as they are actually quite far apart in the band.
Some models do, and it could definitely be an issue.
To be honest, pretty much anything except Bluetooth operating in the 2.4 GHz band can be a problem for zigbee as zigbee is used in home automation, because zigbee is a very low power protocol, and it just gets drowned out.
mind you - it wont be immediate - it may take a while for your network to rearrange itself. When my Wifi router stomps my zigbee (and the reason I scrapped it) After I figured it out and fixed it - it would usually take about two hours to come back. Don’t even think about testing for 30 mins.
Think ‘freight train’ not ‘sportscar.’ Or Harley-Davidson Road Glide CVO vs. a 'Busa…
NO I scrapped the WiFi router and moved to new WiFi6 gear.
I wanted to scrap the neighbor’s router(s) - but something about breaking and entering, destruction of property and a few other annoyances changed my mind.
