Zigbee Discovery not triggering on Built-in TV Hub (April 2024)
Some Nedis devices use the same outer cases as some Aqara devices, but they are different companies and the firmware is quite different as are the fingerprints.
Most nedis devices use Tuya firmware, which can be quite tricky to get to work with SmartThings. If your devices say they use the “Smartlife“ app, then they are using Tuya firmware.
If your devices are Tuya based, start with the following community FAQ, and it may help.
FAQ: Using Tuya Zigbee Devices Directly With a SmartThings/Aeotec Hub (2024)
If they are actually aqara devices, then it should be much simpler and you just have to find an edge driver with the correct matching fingerprint.
