Has anyone actually gotten the Zooz Zen20 version 1.0 powerstrip to work in the new app? I can power on/off the entire strip, but none of the child devices for the individual outlets respond. I tried removing the device and rejoining it. It created new child devices when the strip was added from the new app, but still the child devices don’t respond.
TylerDurden:
The link below is for the built-in handler which probably wasn’t updated for component device support in the new mobile app.
If you replace lines 214-216 with the line below and install it as a new handler, it should create working child devices the next time you join it.
isComponent: false])
* Zooz ZEN20 Power Strip Outlet
* Implementation of the Zooz ZEN20 power strip that uses the new composite device capabilities to provide individual
* control of each outlet from SmartApps as well as the mobile app. Incorporates contributions from:
* Eric Maycock (https://github.com/erocm123/SmartThingsPublic/blob/master/devicetypes/erocm123/zooz-power-strip.src/zooz-power-strip.groovy)
* Robert Vandervoort (https://github.com/robertvandervoort/SmartThings/blob/master/zooZ-Strip-ZEN20/device_type-zooZ-strip-ZEN20_v1.0)
* Copyright 2017 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
This file has been truncated. show original
Thanks @krlaframboise , that did the trick.
