Z-Wave thermostats stopped working – SmartThings Hub V3
I need help with my SmartThings Hub V3 and four Heatit Z-TRM3 Z-Wave thermostats.
All four thermostats stopped working in SmartThings after I changed my home Wi-Fi network. The hub is online, and my Zigbee lights work normally.
I have tried restarting the hub, repairing the Z-Wave network, and removing and reconnecting two thermostats.
The thermostats can be added again, but they show “NaN” instead of temperature, cannot be controlled through the app, and eventually go offline again.
I am using the HeatIt Z-Wave Thermostat 1.5 Edge driver. The thermostats work manually, and the hub is only about 3 metres away.
Could you please help me investigate whether there is an issue with the hub’s Z-Wave communication or software?
I went through something very similar when I swapped out my router last year — my Z-Wave devices shouldn’t have cared about Wi-Fi at all, but everything had to rejoin and a few came back half-working like this. The “NaN” reading usually means the hub added the device but isn’t successfully exchanging reports with it, so I’d suspect the driver or the security handshake first rather than the hub hardware.
Two things I’d try on one thermostat as a test: first, check the hub’s driver menu to make sure that Edge driver is actually installed and current, and reinstall it from the channel if there’s an update pending. Then exclude the thermostat fully and re-add it using the least-secure inclusion option it offers — mine behaved much better after that. Then run one Z-Wave repair and give it a few hours, even overnight; the temperature readings didn’t stabilize for me right away either.
If that one thermostat comes back to life while the others stay flaky, you’ve narrowed it down to the inclusion/security pairing rather than the hub’s radio. Good luck, hope they come back.
Since all four thermostats are showing the same issue, I’d suspect a Z-Wave communication or Edge driver problem rather than faulty thermostats. Have you tried checking the hub’s Z-Wave logs or switching to another compatible driver to see if the temperature readings return?
Thank you so much for taking the time to share your experience and suggestions! I really appreciate it! :blush:
I’ve now checked the Edge driver, excluded all the thermostats, and tried adding one back using the less secure option. Unfortunately, I’m still getting the same NaN readings, and the device log is completely empty.
I’ll try running a Z-Wave repair and give it some more time, as you suggested.
Thanks again for your help! It’s really encouraging to hear from someone who’s experienced something similar. Fingers crossed! :crossed_fingers:
Thank you so much for your suggestions! :blush:
I’ve already checked and reinstalled the Heatit Edge driver. I also tried switching all four thermostats to the Z-Wave Electric Meter driver before switching them back, but unfortunately that didn’t solve the issue.
I’ve also tried excluding and re-adding the thermostats, but I’m still getting NaN readings and empty device logs.
Do you happen to know of another compatible driver I could try for the Heatit Z-TRM3?
Really appreciate your help! :folded_hands:
hank you so much for your help and suggestions! :blush:
Luckily, I finally managed to get it working! :tada: The solution was to factory reset the thermostats and add them back to SmartThings, skipping the secure setup.
Everything is working perfectly now! Really appreciate everyone who took the time to help! :folded_hands:
