Z-Wave Thermostat Battery Status?
Hi,
I have two 2Gig CT101 Thermostats that seem to be operating well using the Better ZWave Thermostat device-type. The problem is that neither the Z-Wave Thermostat, nor the Better Z-Wave Thermostat gather and display battery status. Since I do not have a C-wire connected to either of the thermostats I need to keep a close eye on the battery level. Anyone have a version of the device-type with battery status?
RD
Here it is; it also automatically sets the clock (you’ll need to change the timezone in the code if you are not eastern time; I was too lazy to make it a parameter):
metadata {
	// Automatically generated. Make future change here.
	definition (name: "Z-Wave thermostat with battery level", author: "minollo") {
		capability "Relative Humidity Measurement"
		capability "Battery"
		capability "Temperature Measurement"
		capability "Thermostat"
		capability "Polling"
		command "poll"
	// simulator metadata
	simulator {
		status "off"			: "command: 4003, payload: 00"
		status "heat"			: "command: 4003, payload: 01"
		status "cool"			: "command: 4003, payload: 02"
		status "auto"			: "command: 4003, payload: 03"
		status "emergencyHeat"	: "command: 4003, payload: 04"
		status "fanAuto"		: "command: 4403, payload: 00"
		status "fanOn"			: "command: 4403, payload: 01"
		status "fanCirculate"	: "command: 4403, payload: 06"
		status "heat 60"        : "command: 4303, payload: 01 01 3C"
		status "heat 68"        : "command: 4303, payload: 01 01 44"
		status "heat 72"        : "command: 4303, payload: 01 01 48"
		status "cool 72"        : "command: 4303, payload: 02 01 48"
		status "cool 76"        : "command: 4303, payload: 02 01 4C"
		status "cool 80"        : "command: 4303, payload: 02 01 50"
		status "temp 58"        : "command: 3105, payload: 01 22 02 44"
		status "temp 62"        : "command: 3105, payload: 01 22 02 6C"
		status "temp 70"        : "command: 3105, payload: 01 22 02 BC"
		status "temp 74"        : "command: 3105, payload: 01 22 02 E4"
		status "temp 78"        : "command: 3105, payload: 01 22 03 0C"
		status "temp 82"        : "command: 3105, payload: 01 22 03 34"
		status "idle"			: "command: 4203, payload: 00"
		status "heating"		: "command: 4203, payload: 01"
		status "cooling"		: "command: 4203, payload: 02"
		status "fan only"		: "command: 4203, payload: 03"
		status "pending heat"	: "command: 4203, payload: 04"
		status "pending cool"	: "command: 4203, payload: 05"
		status "vent economizer": "command: 4203, payload: 06"
		// reply messages
		reply "2502": "command: 2503, payload: FF"
	tiles {
		valueTile("temperature", "device.temperature", width: 2, height: 2) {
			state("temperature", label:'${currentValue}°', unit:"F",
				backgroundColors:[
					[value: 31, color: "#153591"],
					[value: 44, color: "#1e9cbb"],
					[value: 59, color: "#90d2a7"],
					[value: 74, color: "#44b621"],
					[value: 84, color: "#f1d801"],
					[value: 95, color: "#d04e00"],
					[value: 96, color: "#bc2323"]
		standardTile("mode", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
			state "off", label:'${name}', action:"switchMode"
			state "heat", label:'${name}', action:"switchMode"
			state "emergencyHeat", label:'${name}', action:"switchMode"
			state "cool", label:'${name}', action:"switchMode"
			state "auto", label:'${name}', action:"switchMode"
		standardTile("fanMode", "device.thermostatFanMode", inactiveLabel: false, decoration: "flat") {
			state "fanAuto", label:'${name}', action:"switchFanMode"
			state "fanOn", label:'${name}', action:"switchFanMode"
			state "fanCirculate", label:'${name}', action:"switchFanMode"
		controlTile("heatSliderControl", "device.heatingSetpoint", "slider", height: 1, width: 2, inactiveLabel: false) {
			state "setHeatingSetpoint", action:"thermostat.setHeatingSetpoint", backgroundColor:"#d04e00"
		valueTile("heatingSetpoint", "device.heatingSetpoint", inactiveLabel: false, decoration: "flat") {
			state "heat", label:'${currentValue}° heat', unit:"F", backgroundColor:"#ffffff"
		controlTile("coolSliderControl", "device.coolingSetpoint", "slider", height: 1, width: 2, inactiveLabel: false) {
			state "setCoolingSetpoint", action:"thermostat.setCoolingSetpoint", backgroundColor: "#1e9cbb"
		valueTile("coolingSetpoint", "device.coolingSetpoint", inactiveLabel: false, decoration: "flat") {
			state "cool", label:'${currentValue}° cool', unit:"F", backgroundColor:"#ffffff"
		standardTile("refresh", "device.thermostatMode", inactiveLabel: false, decoration: "flat") {
			state "default", action:"polling.poll", icon:"st.secondary.refresh"
		standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat") {
			state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
		main "temperature"
		details(["temperature", "mode", "fanMode", "heatSliderControl", "heatingSetpoint", "coolSliderControl", "coolingSetpoint", "refresh", "configure"])
def parse(String description)
	def map = createEvent(zwaveEvent(zwave.parse(description, [0x42:1, 0x43:2, 0x31:3, 0x80:1])))
	if (!map) {
		return null
	def result = [map]
	if (map.isStateChange && map.name in ["heatingSetpoint","coolingSetpoint","thermostatMode"]) {
		def map2 = [
			unit: "F"
		if (map.name == "thermostatMode") {
			updateState("lastTriedMode", map.value)
			if (map.value == "cool") {
				map2.value = device.latestValue("coolingSetpoint")
				log.info "THERMOSTAT, latest cooling setpoint = ${map2.value}"
			else {
				map2.value = device.latestValue("heatingSetpoint")
				log.info "THERMOSTAT, latest heating setpoint = ${map2.value}"
		else {
			def mode = device.latestValue("thermostatMode")
			log.info "THERMOSTAT, latest mode = ${mode}"
			if ((map.name == "heatingSetpoint" && mode == "heat") || (map.name == "coolingSetpoint" && mode == "cool")) {
				map2.value = map.value
				map2.unit = map.unit
		if (map2.value != null) {
			log.debug "THERMOSTAT, adding setpoint event: $map"
			result << createEvent(map2)
	} else if (map.name == "thermostatFanMode" && map.isStateChange) {
		updateState("lastTriedFanMode", map.value)
	log.debug "ParseEx returned $result"
	result
// Event Generation
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd) {
	def nowTime = new Date().time
	state.lastBatteryGet = nowTime
	def map = [ name: "battery", unit: "%" ]
	if (cmd.batteryLevel == 0xFF || cmd.batteryLevel == 0) {
		map.value = 1
		map.descriptionText = "$device.displayName battery is low!"
    } else {
		map.value = cmd.batteryLevel
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatsetpointv2.ThermostatSetpointReport cmd)
	def map = [:]
	map.value = cmd.scaledValue.toString()
	map.unit = cmd.scale == 1 ? "F" : "C"
	map.displayed = false
	switch (cmd.setpointType) {
		case 1:
			map.name = "heatingSetpoint"
			break;
		case 2:
			map.name = "coolingSetpoint"
			break;
		default:
			return [:]
	// So we can respond with same format
	state.size = cmd.size
	state.scale = cmd.scale
	state.precision = cmd.precision
	map
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv3.SensorMultilevelReport cmd)
	log.debug "SensorMultilevelReport ${cmd}"
	def map = [:]
	switch (cmd.sensorType) {
		case 1:
			// temperature
			map.value = cmd.scaledSensorValue.toString()
			map.name = "temperature"
			break;
		case 5:
			// humidity
			map.value = cmd.scaledSensorValue.toInteger().toString()
			map.unit = "%"
			map.name = "humidity"
			break;
    map
def zwaveEvent(physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport cmd)
	def map = [:]
	switch (cmd.operatingState) {
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_IDLE:
			map.value = "idle"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_HEATING:
			map.value = "heating"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_COOLING:
			map.value = "cooling"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_FAN_ONLY:
			map.value = "fan only"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_PENDING_HEAT:
			map.value = "pending heat"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_PENDING_COOL:
			map.value = "pending cool"
			break
		case physicalgraph.zwave.commands.thermostatoperatingstatev1.ThermostatOperatingStateReport.OPERATING_STATE_VENT_ECONOMIZER:
			map.value = "vent economizer"
			break
	map.name = "thermostatOperatingState"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport cmd) {
	def map = [:]
	switch (cmd.mode) {
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_OFF:
			map.value = "off"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_HEAT:
			map.value = "heat"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_AUXILIARY_HEAT:
			map.value = "emergencyHeat"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_COOL:
			map.value = "cool"
			break
		case physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeReport.MODE_AUTO:
			map.value = "auto"
			break
	map.name = "thermostatMode"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport cmd) {
	def map = [:]
	switch (cmd.fanMode) {
		case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_AUTO_LOW:
			map.value = "fanAuto"
			break
		case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_LOW:
			map.value = "fanOn"
			break
		case physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeReport.FAN_MODE_CIRCULATION:
			map.value = "fanCirculate"
			break
	map.name = "thermostatFanMode"
	map
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev2.ThermostatModeSupportedReport cmd) {
	def supportedModes = ""
	if(cmd.off) { supportedModes += "off " }
	if(cmd.heat) { supportedModes += "heat " }
	if(cmd.auxiliaryemergencyHeat) { supportedModes += "emergencyHeat " }
	if(cmd.cool) { supportedModes += "cool " }
	if(cmd.auto) { supportedModes += "auto " }
	updateState("supportedModes", supportedModes)
def zwaveEvent(physicalgraph.zwave.commands.thermostatfanmodev3.ThermostatFanModeSupportedReport cmd) {
	def supportedFanModes = ""
	if(cmd.auto) { supportedFanModes += "fanAuto " }
	if(cmd.low) { supportedFanModes += "fanOn " }
	if(cmd.circulation) { supportedFanModes += "fanCirculate " }
	updateState("supportedFanModes", supportedFanModes)
def updateState(String name, String value) {
	state[name] = value
	device.updateDataValue(name, value)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
	log.debug "Zwave event received: $cmd"
def zwaveEvent(physicalgraph.zwave.Command cmd) {
	log.warn "Unexpected zwave command $cmd"
// Command Implementations
def poll() {
	delayBetween([
		zwave.sensorMultilevelV3.sensorMultilevelGet().format(), // current temperature
		zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 1).format(),
		zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: 2).format(),
		zwave.thermostatModeV2.thermostatModeGet().format(),
		zwave.thermostatFanModeV3.thermostatFanModeGet().format(),
		zwave.thermostatOperatingStateV1.thermostatOperatingStateGet().format(),
		getBattery(),
        setClock()
	], 2300)
private getBattery() {	//once every 10 hours
	def ageInMinutes = state.lastBatteryGet ? (nowTime - state.lastBatteryGet)/60000 : 600
    log.debug "Battery report age: ${ageInMinutes} minutes"
    if (ageInMinutes >= 600) {
        log.debug "Fetching fresh battery value"
		zwave.batteryV1.batteryGet().format()
    } else "delay 87"
private setClock() {	//once a day
	def ageInMinutes = state.lastClockSet ? (nowTime - state.lastClockSet)/60000 : 1440
    log.debug "Clock set age: ${ageInMinutes} minutes"
    if (ageInMinutes >= 1440) {
        log.debug "Setting clock"
		state.lastClockSet = nowTime
        def nowCal = Calendar.getInstance(TimeZone.getTimeZone("America/New_York"));
		zwave.clockV1.clockSet(hour: nowCal.get(Calendar.HOUR_OF_DAY), minute: nowCal.get(Calendar.MINUTE), weekday: nowCal.get(Calendar.DAY_OF_WEEK)).format()
    } else "delay 87"
def setHeatingSetpoint(degreesF) {
	setHeatingSetpoint(degreesF.toDouble())
def setHeatingSetpoint(Double degreesF) {
	def p = (state.precision == null) ? 1 : state.precision
	delayBetween([
		zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 1, scale: 1, precision: p, scaledValue: degreesF).format(),
def setCoolingSetpoint(degreesF) {
	setCoolingSetpoint(degreesF.toDouble())
def setCoolingSetpoint(Double degreesF) {
	delayBetween([
		zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: 2, scale: 1, precision: p,  scaledValue: degreesF).format(),
def configure() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSupportedGet().format(),
		zwave.thermostatFanModeV3.thermostatFanModeSupportedGet().format(),
		zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:[zwaveHubNodeId]).format()
	], 2300)
def modes() {
	["off", "auto", "emergencyHeat", "heat", "cool"]
def switchMode() {
	def currentMode = device.currentState("thermostatMode")?.value
	def lastTriedMode = getDataByName("lastTriedMode") ?: currentMode ?: "off"
	def supportedModes = getDataByName("supportedModes")
	def modeOrder = modes()
	def next = { modeOrder[modeOrder.indexOf(it) + 1] ?: modeOrder[0] }
	def nextMode = next(lastTriedMode)
	if (supportedModes?.contains(currentMode)) {
		while (!supportedModes.contains(nextMode) && nextMode != "off") {
			nextMode = next(nextMode)
	switchToMode(nextMode)
def switchToMode(nextMode) {
	if(supportedModes && !supportedModes.contains(nextMode)) log.warn "thermostat mode '$nextMode' is not supported"
	if (nextMode in modes()) {
		updateState("lastTriedMode", nextMode)
		return "$nextMode"()
	} else {
		log.debug("no mode method '$nextMode'")
def switchFanMode() {
	def currentMode = device.currentState("thermostatFanMode")?.value
	def lastTriedMode = getDataByName("lastTriedFanMode") ?: currentMode ?: "off"
	def supportedModes = getDataByName("supportedFanModes") ?: "fanAuto fanOn"
	def modeOrder = ["fanAuto", "fanCirculate", "fanOn"]
	while (!supportedModes?.contains(nextMode) && nextMode != "fanAuto") {
	switchToFanMode(nextMode)
def switchToFanMode(nextMode) {
	def supportedFanModes = getDataByName("supportedFanModes")
	if(supportedFanModes && !supportedFanModes.contains(nextMode)) log.warn "thermostat mode '$nextMode' is not supported"
	def returnCommand
	if (nextMode == "fanAuto") {
		returnCommand = fanAuto()
	} else if (nextMode == "fanOn") {
		returnCommand = fanOn()
	} else if (nextMode == "fanCirculate") {
		returnCommand = fanCirculate()
	} else {
		log.debug("no fan mode '$nextMode'")
	if(returnCommand) updateState("lastTriedFanMode", nextMode)
	returnCommand
def getDataByName(String name) {
	state[name] ?: device.getDataValue(name)
def getModeMap() { [
	"off": 0,
	"heat": 1,
	"cool": 2,
	"emergency heat": 4
def setThermostatMode(String value) {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: modeMap[value]).format(),
def getFanModeMap() { [
	"auto": 0,
	"on": 1,
	"circulate": 6
def setThermostatFanMode(String value) {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: fanModeMap[value]).format(),
def off() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 0).format(),
def heat() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 1).format(),
def emergencyHeat() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 4).format(),
def cool() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 2).format(),
def auto() {
	delayBetween([
		zwave.thermostatModeV2.thermostatModeSet(mode: 3).format(),
def fanOn() {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 1).format(),
def fanAuto() {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 0).format(),
def fanCirculate() {
	delayBetween([
		zwave.thermostatFanModeV3.thermostatFanModeSet(fanMode: 6).format(),
That’s great - thanks!
You can also do location.timeZone to get the user’s time zone
That’s an excellent hint, thanks!
Did anyone get this to work recently?
I get the following error:
No signature of method: script1414781569758229339352.metadata() is applicable for argument types: (script1414781569758229339352$_run_closure1) values: [script1414781569758229339352$_run_closure1@5b8edd3d] Possible solutions: getMetadata(), getState(), setState(java.lang.Object), metaClass(groovy.lang.Closure)
I don’t see any problem; I suppose you understand this is source code for a device type, not a smart app.
Kinda basic question but what’s the difference from a user perspective. ie… how does one vs a device type vs app?
A device type is code which deals with the physical device communication; a smartapp is code which contains logic to deal with some behavior you want to apply to one or more devices, based possibly on the state of one or more other devices, and/or other external factors (time, weather, mode, …).
I didn’t go through it lately, but I’m pretty sure ST’s documentation contains some discussion about the topic.
Got it thanks, any idea why ST doesn’t include your code as part of their default device feature set?
No idea; I suppose testing it against a multitude of different zwave thermostats out there is an expensive, and low priority work item.
If you don’t mind me asking, was this code written from scratch or the base code from ST taken and features added?
What I mean to ask is if there are updates or bug fixes then how does one get them?
The latter.
Not sure there are many (any?) changes happening on the “base code”; I haven’t noticed any lately.
@Ben it would be great if ST can include this code for Battery reading and time setting feature into the default ST device app.
I create a new device using this and associated the existing thermostat with this device but I still don’t see any battery or time. What am I missing here?
Funny thing with this code and my CT100 now it doesn’t even control the fan or mode (I don’t see time / battery anywhere).
But if I switch back to the default Z-Wave Thermostat it works but with no battery/time status.
Do you know how we can get the code for the latest version of the Z-Wave thermostat device?
Don’t know why you wouldn’t see battery status; if you check the live logging, do you see any “battery related traffic” logged for the device? As you can see from the code, there is some information logged there.
Time is a different topic; the code is meant to send the correct time to the device, not vice-versa.
The default zwave code is available as part of the default device types; you can see it if you create a new device type - where you can choose among all the officially supported device types to start as a template.
I see the logging in the activity, just don’t see a title for it. I’m guessing that depending up on the app and not the device type right?
I’m sorry but I didn’t understand how to find/use the template. When I click on new Device Type under My Devices, it gives me many check boxes for “Capabilities”. I don’t see anywhere to select the Device Type template, what am I missing here?
For some reason the Fan and mode buttons aren’t working on the CT100 with the code above but the default is so I wanted to the default to add your code to it. thanks
Just create a new device type with name and namespace “test”; once in the code window, you’ll have a button on the top-right of the page, “Device Type Examples”; click it, scroll down, and you’ll find the zwave thermostat one.
The logging I was referring to is device specific, nothing to do with the application:
} else “delay 87”
THE LATEST WORKING CODE HAS NOW BEEN MOVED HERE TO MAKE IT EASIER TO ACCESS AND READ
@minollo thanks for this. @duncan thanks for the Humidity multiinstance code for CT-100/101
@Ben something ST can look at including in the default code to include a battery tile and set time or create a custom device type for CT100/CT101.
BTW I should be tagging someone else from your team or sharing my thoughts with anyone else on the ST team in your place please let me know Ben.
