I always wondered if it were possible to pair up a jasco on/off master switch to an enerwave auxiliary and vice versa? Also, would it be possible to run a 3 way switch with a manual switch on one side and zwave master on the other ?
I
I
Your best bet is to use the pair as designed.
Common sense tells me the same. Reason why I asked is because I have a couple of pure white enerwave masters and cannot find auxilary switches in the same color.
Thanks for the input @jerzydiver
In examining the switches they look to be identical as they both contain the same 3 wire input with NO load or power being applied to it. I would try it but is a test environment outside of the wall (test bed) just in case.
I may have to rig up something to test that. I definitely dont want wiring melting behind the wall. No telling what could happen.
I agree As i did examine the wiring on both and they are identical which tells me they are acting in the same manner. But it is a house and deserves the respect to be sure.
That’s not possible unless you are using a z-wave relay module. Then you don’t need a smart switch at both end.
As for mix and match. I do mix Dragon Tech, jasco and GE. They are the same maker according to the circuit board inside. I wouldn’t mix any other switches that I am not sure off.
