Does anyone know if you install a smart relay modules example Enerwave ZWN-RSM2 does it show the status of the Aux 1 & 2 inputs on smart things or just the outputs. I want to monitor a 120V feed and sense if it is on. My application needs does not allow me to use a plug in unit to monitor power consumption so I am just looking to sense 120vac on one of the inputs and I would not use the relay outputs. Yes I do have a neutral and a constant 120vac that would be used to power the unit.
