I got the device handler. Works much better.
Thanks. Appreciate the help.
I would like to point out that this device is listed as Works With Smartthings and IMHO it does not; Without adding custom code and knowing and willing to how to work around several limitations.
Most people who would read that it “Works With Smartthings” are NOT able and willing to perform these tasks.
It is very hard to recommend Smartthings to “typical” consumers as it appears to be aimed at hobbyist will to add custom code and tolerate the poor documentation.
Just in case anyone else gets this lock and doesn’t want to waste hours pairing like me, make sure you click the gear icon after selecting “1” to enter wave pairing mode. I kept hitting “1” and hearing the lock announce pairing mode and then timing out.
I also put my hub on battery right next to the lock for this with a power line Ethernet port/cable. A cheap Ethernet/WiFi bridge paired to your network would also work well if necessary…
