Is there a fix for this?
When navigating to SmartThings. Add a little smartness to your things. it states i don’t have any hubs, however if i click on location i can access my hub from there. Slight bug but annoying
That link is to a page on graph.api.smartthings.com. It sounds like your Location is on a different ‘shard’ (so a different URL). What you are describing is actually perfectly normal and correct behaviour as if you are a member of multiple Locations they may be on different shards.
If you use https://account.smartthings.com/ to access the IDE you will normally get redirected to the best starting shard for you.
