I get the error when trying to add in settings. “You don’t have access to tonesto7/st-community-installer”
probably because you misspelled tonesto7
Owner: tonesto7
Branch: Master
You can copy and paste the above if needed
I may have here but on the computer I copied and pasted
can you post a screenshot of that portion of the screen where you are typing that data
Hi i am having the same problem. are you able to resolve the issue. if yes can you please share…
I also am getting the access error with this repository:
*You don't have access to Sandood/Ecobee-Suite*
Based on install instructions at GitHub - SANdood/Ecobee-Suite: Universal Suite for integrating Ecobee thermostats & sensors with Hubitat and SmartThings home automation platforms (Free!)
- Owner:
SANdood<— SAN in caps - Name:
Ecobee-Suite(note that the hyphen is required) - Branch:
master
if it still fails, take a screenshot of your repository settings and disconnect your github account in IDE and reauthenticate
I found the solution in another thread. Click the link that says disconnect then re-enable github and log back in.
My other repository was remembered and adding the new one worked.
