I just added a bunch of window/door sensors tonight, and wanted to install some related smart apps, like the AccuWeather apps. Every time I tried to install and save the app, I would get the
You appear to be having issues with your network. Please check your network connection and try again.
Is this a current problem? Should I just keep trying? Wait till tomorrow?
I get the very same thing. It’s confounding as I’m sitting 4 feet from a wifi base station. Something in the app or its library seems to drop the connection, which is weird!
Usually, if you just try over and over, you’ll eventually get to the next page.
same thing happens to me on wifi very regularly. I have no other issues with my wifi at home. If I connect LTE it unscientifically seems better but will still puke once in awhile.
Well even though I get the error, it appears the Accuweather Connect app installed, as I can see the device and it appears to have the correct temperature, etc.
I tried installing the other Accuweather apps (temperature and rain), and to my surprise, they only support looking at a single window sensor! What if it’s raining and I have some other window open? Doesn’t seem like the best solution on their part…
