This is one for us UK folks.
Smartthings has kindly fixed TTS! YES! for which I am extremely grateful for!
However, I’m wondering if anyone has managed to get the %weathertoday% etc to work as announcements?
I’ve been doing some testing and here’s my findings:
%weathertoday% traced via live logging actually generates the correct text to be announced! However nothing comes out the speakers
%weathertoday(UKPOSTCODE)% causes the app to crash (Big Talker, Rule Machine, Sonos Weather) and then fails to announce anything also, however, it does still generate the =msg text in live logging
%weathertoday(USZIPCODE)% WORKS!
Anyone else been experimenting with UK postcodes for weather?
I have used the sonos weather forecast smart app. If i leave the zip code blank then it does now work! but it just says “the current temperature is 5 degrees” which is not a weather forecast in my book! Are you guys doing this some other way since i cant see a “command to specify a zipcode”. there is just a field for a zipcode.
What is "%weathertoday()% "
where do i type it? in the zipcode box?
