* Version 0.1 -
preferences {
input("userName", "text", title: "Username", description: "Your username for Yale Home System")
input("password", "password", title: "Password", description: "Your Password for Yale Home System")
input("zonenumber", type: "number", title: "Row Number - Put 0 in here and open a window/door, refresh and see if the status changes", description: "Sensor ID")
metadata {
definition (name: "Yale Alarm Open Close Sensor", namespace: "Tapion1ives", author: "Tapion1ives") {
capability "Contact Sensor"
capability "Sensor"
capability "Refresh"
attribute "status", "string"
// UI tile definitions
tiles {
standardTile("contact", "device.contact", width: 2, height: 2) {
state "open", label:'${name}', icon:"st.contact.contact.open", backgroundColor:"#ffa81e"
state "closed", label: '${name}', icon: "st.contact.contact.closed", backgroundColor: "#79b821"
state "Failed", label: '${name}', icon: "st.contact.contact.open", backgroundColor: "#e5e500"
standardTile("refresh", "device.status", inactiveLabel: false, decoration: "flat") {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
main "contact"
details ("contact", "refresh", "bypass")
// Zone status Information is below
// '' – Closed
// device_status.dc_open – Open
// Login Function. Returns SessionID for rest of the functions
def login(token) {
log.debug "Executed login"
def paramsLogin = [
uri: "https://www.yalehomesystem.co.uk/homeportal/api/login/check_login/",
body: [id:settings.userName , password: settings.password]
httpPost(paramsLogin) { responseLogin ->
token = responseLogin.headers?.'Set-Cookie'?.split(";")?.getAt(0)
return token
} // Returns cookie as token
// Logout Function. Called after every mutational command. Ensures the current user is always logged Out.
def logout(token) {
//log.debug "During logout - ${token}"
def paramsLogout = [
uri: "https://www.yalehomesystem.co.uk/homeportal/api/logout/",
headers: ['Cookie' : "${token}"]
httpPost(paramsLogout) { responseLogout ->
log.debug "Smart Things has successfully logged out"
// Gets Panel Metadata. Takes token & location ID as an argument
Map panelMetaData(token) {
def tczones
def getPanelMetaDataAndFullStatus = [
uri: "https://www.yalehomesystem.co.uk/homeportal/api/panel/get_devices/",
body: [id:settings.userName , password: settings.password],
httpPost(getPanelMetaDataAndFullStatus) { response ->
tczones = response.data.message
return [tczones: tczones]
} //Should return Sesor and description Information
def refresh() {
def token = login(token)
def zname = device.name
def zonenumber = settings.zonenumber as int
def metaData = panelMetaData(token) // Gets Information
log.debug "Doing zone refresh"
if (metaData.tczones.contains("system.permission_denied")) {
log.debug "Zone ${metaData.tczones} is Fault"
sendEvent(name: "contact", value:"Failed", displayed: "true", description: "Refresh: Zone is Faulted", linkText: "Zone ${zname} faulted", isStateChange: "true")
} else if (metaData.tczones[zonenumber].status1.contains('device_status.dc_open')) {
log.debug "Zone ${metaData.tczones[zonenumber].status1} is OPEN"
sendEvent(name: "contact", value:"open", displayed: "true", description: "Refresh: Zone is Open", linkText: "Zone ${metaData.tczones[zonenumber].status1} - ${zname}", isStateChange: "true")
} else if (metaData.tczones[zonenumber].status1.contains('')) {
log.debug "Zone ${metaData.tczones[zonenumber].status1} is OK"
sendEvent(name: "contact", value:"closed", displayed: "true", description: "Refresh: Zone is closed", linkText: "Zone ${metaData.tczones[zonenumber].status1} - ${zname}", isStateChange: "true")
logout(token)
sendEvent(name: "refresh", value: "true", displayed: "true", description: "Refresh Successful")
log.debug "Parsing '${description}'"
