Would just like to find out from users who are using the Aqara Motion Sensor, which DH are you guys using and does it report the lux reading as well?
As per this description here, it says it can detect light intensity - Xiaomi Aqara Motion Sensor
Alsoā¦for the Xiaomi zigbee outlets, does the DH from @a4refillpad have the power reading? Just checking all the boxes before i start outfitting my place with Xiaomi products
I try te code for Aqara door sensor but now I have
āSomethings wrongā
āWe canāt load your screen right now.ā
I mentioned a few months ago that popping off the back of the Xiaomi door/window sensor and connecting the two large solder points resulted in a āclosedā state. I finally got around to testing this as a method of integrating hard-wired alarm contacts to ST. Unfortunately I havenāt soldered since high school electronics class (1999) and my $5 soldering iron didnāt work very well, but the concept worked.
Solve just wait the ST refresh value from Xiaomi sensor
Anyone interested the Aqara sensors are dirt cheap (Flash Sale) on GearBest at the moment (Ā£5.34). Beggars belief how they make a profit on these!
http://www.gearbest.com/access-control/pp_626703.html
The Xiaomi ones are not that much more expensive either.
Hi,
Can the Xiomi products and Aqara products be easily integrated with Smartthings European version ?
I would like to buy button switches and light bulbs.
Thank you.
Daniel Duarte
I am using xiaomi windows sensors and button with UK hub, for xiaomi light bulb (yeelight) there is no direct support and needs a pc/pi running node.js as the bridge or you can use ifttt
I have two of the Xiaomi motion sensors. I got them both paired easy enough but after about an hour they stopped reporting motion. They still appear to be paired, the communicate with pollster but donāt report motion. Any ideas how to fix this?
Which Device Handler are you using?
They should stay online and report motion along with battery after a period of time. You could remove them, reset the sensors and try to pair them again, perhaps they just did not join properly before.
Also what is your Hubs Firmware version?
Hub firmware us 2.5.0
Iāll try repairing.
Just weird because it worked fine for about the first hour
Some tips for pairing these successfully -
Be really close to the hub when adding them, this is not critical but it really does help if you have problems pairing.
Go with the flow of the flashes from the device, click, it flashes and you get some flashes back, click again and so onā¦rather than just clicking randomly.
When adding through the app donāt save it as soon as it appears (whilst the circle is still spinning) carry on clicking the reset until the circle has stopped spinning and (iirc) the info text changes from ādevices foundā to ā1 device foundā
Donāt add to pollster until the device has paired successfully showing battery percentage, I donāt know if this makes the slightest bit of difference as I donāt use pollsterā¦itās just my own preference to not add to smart apps until successfully paired.
Those are just my observations, itās quite possible you could do everything completely different to that and still achieve successful pairing!
Hi
I think you have quoted the app Version.
You need to go into the ide for the Version your hub is running.
If itās 17.xx OR 18.21 then theāre should not be an issue and try re-pairing the sensors.
If itās 18.18 or 18.20 then there is an issue and the sensors will not stay paired.
Oh you are right. The firmware version is 000.017.00012
Hey Bob!
Hope all working a little better for you now
As an fyi you can actually see the Hub f/w version from the app, go into the Hamburger Menu and click on āHub is Onlineā the info is listed there.
However! For some reason if I do this on iOS it shows my version to be .18, on droid it shows it as .21 lol. Can only assume this maybe down to the fact that android updated a few days back but iOS has not had such a recent update. Either way the info does not appear to be reliable so looking in the IDE is the way to go because that must be correct right lol
You should not have any issues with that f/w version as the problems were introduced with .18 and fixed with .21.
Which DH are you using?
I would remove them, reset them and follow Mikeās steps just above to try and pair them again.
Few things;
I know what you mean about the app being incorrect.
Iām still showing 18.20 but Iām actually 18.21 in the ide.
Ok thanks, Iāll give that a try
thanks to TS for the device handlers. They are great.
Been noticing a delay in motion detection to triggered event, anyone seeing the same ?
Yes Zigbee EU or US is the same.
Itās not like Zwave.
I use a lot of Xiaomi in my ST UK
