I believe on you so i close this topic
I have a weird issue with the temp/humidity sensor. The catchall didnāt quite look right as it showed 0000 for the id. The sensor is sending the temperature and humidity to the log. I put it in the freezer to be sure it wasnāt from something else I have paired and didnāt realize was sending that info. Is there a way to get the correct Id from the data sent. Everything Iāve tried doesnāt work. Thanks for any help.
Edit: I got it. Luckily a raw data event got sent with the zigbee and network idās.
Hi my devices just arriveā¦
I connect Temperature Sensor on Xiaomi Hub
I got this information from Xiaomi App on Android app
I believe the ID: 158d00010fc280
I removed Temperature Sensor from Xiaomi Hub
I added on IDE
But I can see temperature and Hunmidity
You can always use these instructions to get the temp sensor working:
Hi @brumster, Thank you for this instructions, I tried this too yesterday, I cant see nothing on IDE :(.
I will try again this night.
about step 4 - Using the IDE look at the logs, not the live logging but the hub log (select hub, then select events)
Could confirm this instructions
My Hubs > List Events > Wanting for informationā¦
Yep, thatās correct.
Iād almost given up myself on getting this working but stick with it, it will work.
Add a Thing
Press and hold the button until you get three flashes
Keep doing that until you get 2 LED flashes for every consecutive button press
Then look in the hub log (not live logging) for the a catchall event at about the same time as you held the temp sensor button until you got 3 flashes.
Then you can create the device via the ID using the hex value you hopefully find.
good luck
Need some help. I paired my motion sensor by using the catchall and adding the device manually. Whatever I try I canāt get the battery level to start reporting.
I tried pairing it directly and nothing showed up.
i didnāt have to do the manual catchall for the motion. Just reset, press furiously and repeat.
Ok what exactly is the reset process? Can you please list the steps? Thanks.
Hold the button until you get 3 flashes
Just tried it and although its resetting, its not showing up in add things. Also furious pressing killed one of my motion sensors
Very strange I did 10 in a row pretty easily.
You just hold the pin in it blinks a few times when it stops blinking, hold it down again. Keep on going with this process until a thing shows.
One you have the device handler itāll appear as the motion sensor instead of a thing. If after an hour temperature doesnāt appear then it hasnāt paired properly and will drop.
My technique seems to be once it appears paired to do a few short clicks right after. Seems to then do something to the device to stop it from dropping.
Iāll give it a go on another one (I have 10 of these).
Tried about 20 times. Still no go. Also usually how long does battery take to start showing updates?
EDIT: I added 3 sensors using the IDE and one of them has started to report battery. The other 2 havenāt dropped off yet, will wait and see.
EDIT 2: The dead sensor is still dead
Just got my Xiaomi door/window, motion, and temp sensors in today. Got the door/windows and the motion paired up, but Iām not seeing a DH for the temp sensor. Does anyone have one to share? I found a link to one on GH from this thread but it results in a 404 error (not found).
I donāt seem to be able to do any configuration on the motion sensor or the door/windows sensors. The āconfigureā button is there, but doesnāt do anything when pressed. Is this normal?
I set it up with the default temp sensor DH when adding through IDE. However itās not showing anything close to the right temp. I can assure you my fridge is not 78* inside
Hey,
I am trying to setup my Xiaomi door/window sensor. Where did you get the door/window code? All I am getting is 404.
are the batteries on the motion sensor changeable?
Thanks. Got the file but the sensor status always stays āOPENā. I can see the blue led flashing once everytime the magnet gets close/away to/from the sensor.
What could be wrong?
