You have to check the events in the hub events, not live logging.
Just go to the hub, scroll down and click the link “List events”
Edit
ah saw you found it
Edit
ah saw you found it
This works in Canada. I’m in Calgary and have them working
[quote=“No_Name, post:445, topic:31948, full:true”]But problem is that I do not have Xiaomi Hub, and I am not sure if it will work in North America(I am form Canada).
[/quote]
Ciao fabrizio , provato con la successione di tasti “configura” e “refresh” da dentro l’app. In qualche post sopra c’è scritto di fare così e a me ha funzionato
Do u have some device handler for temp sensor to show the battery status too?
Btw ,huge thanks for your effort on this thread, got bunch of different xiaomi sensors ,all working flawlessly.
SmartThings should officially support these sensors and plugs: Build quality is great, size is great, range is great, price is great.
Actually better than most of the competition.
Hopefully they stay connected.
Hi Lorenzo
good to know there are other italians here!
I managed to pair the door sensor properly. I only miss the battery life. will try again next week end. Where do you live? I live in Monza but I use ST in my holiday place in the Alps.
thanks
ciao
f
How can I install the temperature/humidity sensor?
Which device type do I have to install?
Hello
Have you manage to get it to work?
RA
See above.
Dear Fabrizio
I live in florence and i’m a ST newbie!
I believe your are a good expert about ST.
I will still a lor from you
Ciao
L
Hello Brian
How do you add it? I press the button on the device and try to add thing on the app but it does not add.
Rui
To add the temperature sensor:
That should work. The main issue I had was that I was looking in the live log and not the hub log.
Good luck!
Hi all,
Do you think is possible to let a Button become a presence sensor?
Coul be used as keyfob and same time presence sensor.
Because the ST presence sensor is expensive and the batteries drain very fast.
Maybe writing a specific code…
Should be important because Geofancing and presence sensor are to much complicated,
What do you think?
I have thought of that too. But since the button does not regularly ping the hub, you’ll need to physically press the button to send a signal to the hub to let the hub know you’re home. If you can accept the fact that you have to physically click a button, then i guess it will be fine provided the Zigbee device does not drop off the networK being away from the network for a long time
I’m currently planning to develop a Wifi based presence detector using esp8266 but since it uses quite a lot of battery, it needs to be chargeable
Thank you Rave your answer arrive very fast and very detailed, i want to link another question regardinf the button.
I actually programmed the button with one click i set the mode ‘home’ and the action i’m back’, with long pressure i set ‘away’ and ‘goodbye’.
It means i activate and deactivate the alarm.
My question is: do you think is possible to set a combination of click to make a specific action?
EG. i press in sequence 3 times the button i activte the alarm, one click then held than one click again i disarm, all of this action combined with a charm of siren then let u know thaat the mode is changed.
It is possible. You just need to code the handler
But i guess it doesn’t make a lot of sense because you already automate the click again unless you put a delay. Let’s say if you click once and there’s no click in 2 second, it will recognize as a click. If you click within 2 second, it can recognize as another action.
But it’s not simple cause you need to write a smart app for that
I’m too much newbie
The sense is to put outside a button and use a code to disarm the alarm before enter in the home
Then i guess it’s easier to just buy 2 button then…
I see what you’re doing. But i think that’s not a very good idea
