How can I install the temperature/humidity sensor?
Which device type do I have to install?
Thanks!
Thanks!
Hello
Have you manage to get it to work?
RA
See above.
Dear Fabrizio
I live in florence and i’m a ST newbie!
I believe your are a good expert about ST.
I will still a lor from you
Ciao
L
Hello Brian
How do you add it? I press the button on the device and try to add thing on the app but it does not add.
Rui
To add the temperature sensor:
That should work. The main issue I had was that I was looking in the live log and not the hub log.
Good luck!
Hi all,
Do you think is possible to let a Button become a presence sensor?
Coul be used as keyfob and same time presence sensor.
Because the ST presence sensor is expensive and the batteries drain very fast.
Maybe writing a specific code…
Should be important because Geofancing and presence sensor are to much complicated,
What do you think?
I have thought of that too. But since the button does not regularly ping the hub, you’ll need to physically press the button to send a signal to the hub to let the hub know you’re home. If you can accept the fact that you have to physically click a button, then i guess it will be fine provided the Zigbee device does not drop off the networK being away from the network for a long time
I’m currently planning to develop a Wifi based presence detector using esp8266 but since it uses quite a lot of battery, it needs to be chargeable
Thank you Rave your answer arrive very fast and very detailed, i want to link another question regardinf the button.
I actually programmed the button with one click i set the mode ‘home’ and the action i’m back’, with long pressure i set ‘away’ and ‘goodbye’.
It means i activate and deactivate the alarm.
My question is: do you think is possible to set a combination of click to make a specific action?
EG. i press in sequence 3 times the button i activte the alarm, one click then held than one click again i disarm, all of this action combined with a charm of siren then let u know thaat the mode is changed.
It is possible. You just need to code the handler
But i guess it doesn’t make a lot of sense because you already automate the click again unless you put a delay. Let’s say if you click once and there’s no click in 2 second, it will recognize as a click. If you click within 2 second, it can recognize as another action.
But it’s not simple cause you need to write a smart app for that
I’m too much newbie
The sense is to put outside a button and use a code to disarm the alarm before enter in the home
Then i guess it’s easier to just buy 2 button then…
I see what you’re doing. But i think that’s not a very good idea
I believe on you so i close this topic
I have a weird issue with the temp/humidity sensor. The catchall didn’t quite look right as it showed 0000 for the id. The sensor is sending the temperature and humidity to the log. I put it in the freezer to be sure it wasn’t from something else I have paired and didn’t realize was sending that info. Is there a way to get the correct Id from the data sent. Everything I’ve tried doesn’t work. Thanks for any help.
Edit: I got it. Luckily a raw data event got sent with the zigbee and network id’s.
Hi my devices just arrive…
I connect Temperature Sensor on Xiaomi Hub
I got this information from Xiaomi App on Android app
I believe the ID: 158d00010fc280
I removed Temperature Sensor from Xiaomi Hub
I added on IDE
But I can see temperature and Hunmidity
You can always use these instructions to get the temp sensor working:
Hi @brumster, Thank you for this instructions, I tried this too yesterday, I cant see nothing on IDE :(.
I will try again this night.
about step 4 - Using the IDE look at the logs, not the live logging but the hub log (select hub, then select events)
Could confirm this instructions
My Hubs > List Events > Wanting for information…
