I found it.It was actually the firewall!Problem solved.Now I want to see if it works with enabled username and password.
I got the code to work as well, thanks! Works on all 4 TVs, Fire TVs and Raspberry Pi running XBMC and Kodi.
I was going to look into how I could do some type of text to speech but now I can select important notifications to actually STOP my video and with a pause, speak a notification. Read about that here RELEASE Generic Media Renderer (DLNA Speakers). Cheap Sonos Alternative (Update V2)
Thanks for pointing out that thread Chuck, TTS is the last part of my Home Automation setup.
What version of Kodi are you using, is that a skin and what are you using for the tv guide?
i am using openelec which is based on Kodi 14. The skin in the pic above is 1080xf.mb3, let me know if you need more info.
Edit
Forgot to mention that am using serverwmc as my pvr backend.
Iām not sure I understand, Iām a bit lost
So you copy and past the script on a new smartapps, then publishing
But what do you have to do from the Kodi side?
All you have to do is enable Kodiās webserver and make sure the settings in the smartapp match the IP and webserver port of the kodi machine .
Maybe this already does this and I have to wait until I get home to test it out anyhowā¦but is there a way to add functionality for other events? I have a notification when someone knocks on my front door. Would be very cool to have that pop up and let me know on the screen in Kodi in case its too loud or the knock isnāt loud enoughā¦even cooler if I could get Kodi to mute in such cases.
Will this work for Kodi on Android sticks as well?
I am getting this error while creating the smartapp from your code
āgroovy.lang.MissingPropertyException: No such property: id for class: java.lang.String:ā
Any idea why ?
Also do I have to put event ghost notification code as well ?
Does this smartapp still work? Iām looking for a way to display SmartThings notifications while in Kodi.
hey there. Wanted to ask, how did you do this. Mine does not work. Donāt know what Iām doing wrong
Wondering the same.
Not sure if this smartapp still works or not, but Iād went with this one and use webCoRE to trigger the notifications in Kodi.
You had posted about having made some changes and included a link to the code but that link is now dead and just wondering whatever happened with this? Should I use the code thatās posted earlierā¦?
Sorry, I have not used Kodi in years.
