Yes, Iām aware that RTSP is available. . Just mentioned that it needs to be flashed to even begin to be usable outside of the Wyze environment. Good to know that it cam be used with the existing Generic DH. Your link is broken, but other than that, Thanks! Time to flash another camera
Sorry for coming in on the tail end of this. Can you expand on this? To get Wyze into ST the camera needs to be flashed? Is there a link or simple google search suffices? From there I imagine after installing this DH it would be able to be added to ST?
[GSzabados] above has provided a link āWyzeCam Interestingā. Youtube has several tutorials to flash RTSP protocol to Wize Cam. Device handler for ST is another story. The one I have found doesnāt work as is in the new app.
True. The camera doesnāt have enough hardware resources to have both capabilities. Other than cloud storage, I donāt think I would miss much personally, and that is easily solved with a Micro SD card.
thanks! Yea, I found the the HD and SmartApps. Tried it with one of my Dlinks I have laying around. No luck with code as is, in the new ST app and V2 Hub. Iāll hold off flashing one of my Wyze cams until I can find a DH and SmartApp that works.
Yes, I know how to deploy the RTSP ROM and how to go back to stock. My issue now is what to do with it after. I havenāt found a way to integrate it into the new ST app. Iām not much of a coder.
There is no way yet to integrate cameras into the new ST app. Only the Smartthingās developed DHs are working with cameras.
FYI, the RTSP ROM and the DaFang Hack are not the same. DaFang hack givea you full control over the camera with SSH, RTSP, FTP, email, Image Capture, MQTT, etcā¦
Yep. I really like using that feature, and it will suck when the new firmware rolls out and takes that away. Announcement from Wyze said mid-January, so should be any day now.
