Unfortunately, this problem eventually corrected itself for me. I am using this device handler but I am using an older version from a year ago.
My jumper setting is set to momentary also.
I’ve seen in this thread people saying they’re using the mimolite for sensor input and to trigger garage door open. What I’m wondering is the output on this device constant and can be used as a power supply? I’d like to use it connected to a wired sensor on the input side while also connected to a wired siren on output side. If that’s possible then could the siren be controlled independently or would it be only be triggered by the wired sensor?
MIMOlite Device Handler for Latching Relay
Has anyone written a Device Handler for use with the MIMOlite when used in Latching Relay Mode? I would like to monitor a 12vdc output that is constant, and report the status (active or off) to Smarthings so other devices can be triggered. Switching and alarms are not needed for my implementation. Thanks!
