I’ve had a Wiz floodlight connected to SmartThings for five years. This morning it’s no longer in the ST app. Still listed in Wiz application and works fine. How do I get it back into ST? Thanks for your help.
Are you using Matter or the official cloud to cloud (c2c) integration?
If you are using the c2c integration you can refresh the Wiz integration in SmartThings and see if that works. Go to Menu tab in lower right corner > gear in upper right corner > Linked Services > Wiz > Refresh in lower left corner.
Did as you recommended. However, I noticed on the screen before pressing refresh, the light is displayed. Go back to app and it now appears in No Room Assigned. Wasn’t there before, so it WORKED. Thank you!
