By â Not Support up & down notifyâ, do you mean it doesnât support the ability to detect when I get in bed and get out of bed? Does the device handler lack that support because Withings API doesnât allow it or some other reason? Wondering if itâs possible to add the support.
Anyone care to chime in if you know how to change this to lbs versus kilos? Iâm going to give it a go but thought I would ask if anyone has done it already.
I got this error when trying to login in info auth in the APP.
error physicalgraph.app.exception.UnknownDeviceTypeException: Device type âWithings Personâ in namespace âfison67â not found.
I installed the smartapp and device handlers no problem. When I startup the app, I enter the client ID/password from the IDE OAuth screen and I click âCopy wt_urlâ.
I then copy that into the developerâs registration.
Issue comes when I click âUser Informatino Authâ or âuser Metrics authâ. I login fine with my withings account, select one of 2 users, then I get âclient id not authorizedâ.
Anybody got this working ? I followed the slightly confusing instructions, got the withings dev account setup and pasted in the call back from the App code on ST - which is not entirely clear, but then again Iâm not a developerâŠ
I logged in, it obviously sort of works as it retrieved the two users I have setup on my WT account and it asked me which one - then returned âClient ID not authorisedâ just like the others.
Anything really obvious that Iâm doing wrong - I have followed the instructions, as much as I can do do that is.
Figured it out - the WT developers app setup earlier has âclient idâ and âconsumer seceretâ - which translate into client id and âclient passwordâ on the ST app - do this, and everything was fine. Now to find a use-case !
This is certainly a confusing one to install. Iâm getting an error on what I think is the final step.
Here are the steps Iâve followed so far.
1: Install Smartapp & DTH through Smartthings IDE
2: Enable Oauth for the smartapp through IDE
3: Go to SmartApps, My Apps, WT Connector and then CLICK SAVE (If you donât you will get an error)
4: Open app, click âCopy wt_urlâ under config, copy the wt_url address provided
5: Make a Withings developer app (https://account.withings.com/partner/add_oauth2 )
6: Use the wt_url you copied in step 4 under callback url when creating the Withings developer app.
7: Copy the client ID from the withings developer app, go back to the WT Connector app, paste into Client ID.
8: Press Save (App seems to automatically clear this field if you switch windows to copy password)
9: Copy the Consumer Secret from the withings developer app, go back to WT Connector app, paste into Client Password.
10: Press save
11: Open app again and go under Add Page
12: Enter Name, click next
13: Under Auth-User press âClick Hereâ
14: Log into your withings account
15: Select which user you want
16: Your developer app should now come up and you must choose to allow this app
This is as far as Iâve made it so far and getting the following error message
{âerrorsâ:[{âmessageâ:âredirect_uri_mismatch: The redirect URI provided is missing or does not match partner callback urlâ}]}
I have verified that the callback url entered matches exactly to the one provided in the copy wt_url.
