[WITHDRAWN] MyQ LiftMaster/Chamberlain
Ok, so I’m able to reproduce this pretty easily. All I have to do is open the garage with IFTTT and then close it manually at the wall switch. It may take even less than that, but that does it for sure for me as all refreshes after that are worthless.
I’ve been debugging tonight, and it’s really odd. From what I can tell, the polling is working just fine, but no API callouts are happening during the polling, so obviously we’re never going to get fresh data.
The Garage Door Opener device type calls updateDeviceStatus(parent.getDeviceStatus(this) around line 135. That seems to point to the updateDeviceStatus function in the MyQ SmartApp. However, none of my debug statements in the SmartApp are showing up in the log. And the result of the function is ALWAYS “9” which basically means open. As I’m not getting ANY debug lines from the smartapp, I can’t really tell if it’s an issue with SmartThings or if the actual results are just being hidden from me somehow - does ST not do debug logs of nested parent/child objects like this? Not quite sure how to get around it at the moment, but I’ll keep poking.
When you close it manually at the wall switch, is this part of the Chamberlain panel, or is this a relay switch that you have added?
Just the plain ole Liftmaster button on the wall that came with the house.
As I suspected, debugging between child and parent does not work well. childDevices: parent.someMethod(this)
I just confirmed that I can debug using sendPush() which will basically turn my phone into a debugger for the parent thread. Will see what I find with that.
**Update - The refresh method is definitely working and always pulls back the values from API calls. I think the bug may be happening due to conflicts between polling and refreshing at the same time. Seems like the polling is grabbing the old value, which is overriding whatever new value comes around from the refresh.
On a related note, the MyQ internal poll is definitely not working for me at all. So I’m thinking maybe it’s enough if I ONLY set up pollster to refresh ever minute and not do polling at all because the refresh() method basically takes care of that aspect anyway. I believe when I killed the polling in pollster and left refresh, my status was suddenly corrected. I’ll do some testing tomorrow and see if that handles it.
It may even work to have pollster poll instead of refresh but to just not select both. An investigation for another day…
TL;DR; Turn off polling in pollster and only have it refresh. See if that does it for you.
I’m curious if this might be a MyQ server issue, I just ran the actual Chamberlin MyQ App (Android) cause they updated it and it took forever to open and do anything, if there is major delays on their end, this will also cause delays on status for ST. Anyone else confirm the stock app from the Google PlayStore is very slow?
I haven’t noticed any lag in the iOS MyQ App. But the main way to really tell is to manually hit the MyQ API endpoints and view the status there. So far, I’ve seen 100% accurate and instant reporting from there, so it seems unlikely to be any problem with MyQ reporting itself…
The android MyQ app has been going crazy for me today. Giving random old notifications and VERY slow response in the app.
Same on IOS. Near dead. The native Chamberlain MyQ app. BTW, the last app update was weeks back on IOS. Must be their servers.
Just received this email from Liftmaster:::
LiftMaster MyQ® Interruption of Service
We are currently experiencing an interruption in MyQ service. You may not be able to access MyQ via your mobile or the website and may be receiving false notifications. Please rest assured; your doors and gates are not opening and all of your personal data is secure and uncompromised. These are false notifications. Our support and tech teams are working to restore MyQ services as quickly as possible.
Again, we appreciate your patience and are working to bring you secure and reliable service. Thank you for your continued support.
The LiftMaster MyQ Team
Ha! Just when I post how I’ve never had problems with their app. It’s dead for me, too. The API is still working, though, as I’m able to control the door through ST.
Mine was fine till I did an app update, then slow and getting late messages. Reboot Chamberlain Gateway and seem good, but slowly got bad again. I’m sure if their end is bad that ST will act up too.
Just received a notice from Chamberlin they have issues, see below
Chamberlain MyQ® Interruption of Service
We appreciate your patience and are working to bring you secure and reliable service. Thank you for your continued support.
The Chamberlain MyQ Team
Yup, I got them false notification. A few days ago, I thought my door opened by itself. I’m not 100% sure.
I was having issues yesterday too and ready to go full on OfficeSpace … then I received the same email about issues (not sure where they host services, but they should look into doing it better)…in the middle of the night I received:
LiftMaster MyQ® Service Fully Restored
We know that today’s false push notifications were very frustrating. Please know that our MyQ system is up and running, we identified the cause for the error, we implemented a fix; AND we have restored all push notification activity.
Here’s more information about what happened:
Today, the MyQ system did broadcast false push notifications of door openings to many of our users. This event then caused an unusually heavy load on our system which introduced delays in operation. In order to fully restore MyQ service, we temporarily suspended push notifications.
MyQ service including push notifications has been fully restored. Rest assured that your security was not compromised. Thank you for your understanding, patience, and continued support.
LiftMaster MyQ Hand
All issues seem resolved after receiving the all clear email from Chamberlain… Timely status updates and all devices associated seem good now…
I was still getting weirdness if polling ran at the same time as refresh. Checking logs would show the door randomly being marked as open and then closed one minute later. I put in a hack to fix it by basically commenting out the lines in the poll() method altogether and just running refresh once a minute via pollster. So far, the results are 100% correct.
It seems like this is intended to be run with just relying on poll(), but I don’t see how poll() consistently refreshes data from the Chamberlain API. That is only called from refresh, which I don’t believe is called by polling unless it’s happening from some other automatic process
Can you please detail which lines you commented out? And which command in pollster did you use? Refresh, right? What interval are you using? Thanks.
I commented out lines 136 and 137 in the MyQ Garage Door Opener device type. If those line #'s don’t match up for you for some reason, it’s these two:
//updateDeviceStatus(parent.getDeviceStatus(this))
//updateDeviceLastActivity(parent.getDeviceLastActivity(this))
And yep, you got it - just setup refresh in pollster. Currently set to once a minute.
When I get some time, I think I may try modifying the code so that poll() calls refresh and then just using poll() instead of calling refresh directly. I’d like to avoid using pollster if possible just because it spams my activity log too much. But for now, this gets the job done and keeps my door reporting and associated alerts accurate.
Received today, more issues on the host end…
Our MyQ system is experiencing an unplanned interruption in service and we are working to resolve the issue as quickly as possible.
We sincerely apologize for the inconvenience. We understand continuous MyQ service is important to you and we’re doing everything we can to get back up and running. We suggest that during this time you use your remote or wireless keypad for your garage door or gate opener.
We appreciate your patience, and we will provide more information as soon as it becomes available.
Hello. I have copy-ninja up and running. Thanks for that! Owe you a donation.For the most part it works just fine. However, I have two garage doors with a MyQ Garage Hub, Lift master openers and a MyQ sensor on each door. I can open either door from ST manually via either Doors & Locks or Things dashboard. However, when I set the doors up for open on (iPhone) presence I can only get one door (double door/Primary) to open.upon arrival - Note: separate presence iPhone for each door. The other (single) door does not open on arrival. When I try to open it via Doors & Locks or Things it still won’t open. The icon goes to opening then closing. Does Copy-ninja support two separate doors on MyQ? Is the setup the same via My Apps, preferences, etc.?
