I’m trying to figure out how to wire two switches into this, but the words I’m used to seeing and the words I’m seeing aren’t matching up. Can someone tell me what wires on this:
match up to the wires on the simple dumb switches that I have? If someone has a diagram, that’d be great, but I’d take any info you’ve got.
Does this clarify? The diagram shows everything. Your white neutral needs to be branched off from your main (from the breaker) to your loads. The line (usually black) branched from the breaker to your switches.
Then all of the other connections shown, plug into the smart micro switch.
