Windows Phone Update 1.0.3 Release Notes (11/04/2014)
SmartThings version 1.0.3 includes several bug fixes, user interface improvements and overall performance improvements for an improved user experience and increased stability. Below is a more comprehensive list of the changes.
Improvements
  • Increased: size of tappable area for tile settings
  • Added: padding to Sign Up and Log In buttons on the log in screen.
  • Added: SmartSolutions Module INCOMPLETE icon
Bugs
  • Fixed: Font discrepancies by status on Things matrix view
  • Fixed: Users are able to half install dashboard use cases that they cannot delete
  • Fixed: Service Managers Not Installable
  • Fixed: Things: Settings button (gear) for groups does not display
  • Fixed: Thing Detail: Light Level % tile not updated with slider control
  • Fixed: Dashboard: When deleting last use case from a module, you’re taken back to that module instead of the dashboard view
  • Fixed: No error handling/messaging when location services disabled
  • Fixed: Hub activation through Getting Started Experience can be skipped via force close
  • Fixed: SmartSense Multi: Devices not pairing
  • Fixed: Hue bulbs not controllable beyond on/off
  • Fixed: Application crash loading Dashboard after activating hub
  • Fixed: Crash when attempting to delete Hue service manager
  • Fixed: Return button not functional on hub activation
  • Fixed: Application crashes 1st time attempting to log in with post-password reset
  • Fixed: Application re-launches when resuming from tombstoned state
  • Fixed: In Things, SmartThings Moisture sensor displaying as Unknown crash when clicked
  • Fixed: Searching for a device at hub-less location returns technical error
  • Fixed: Crash after viewing Terms of Service and Privacy Policy and switching between Sign Up and Log In
  • Fixed install button displays on Life360 and Jawbone
  • Fixed: Page flow for the Open/Closed Multisensor
  • Fixed: Crash when backgrounding post-install
  • Fixed: Crash when attempting to add a Jawbone device to the Steps Tracker SmartApp
