I have a door sensor on my rear door (double door). We went to sleep, with the alarm on. During the night, we had a lot of wind. At 4 a.m. the wind push our rear door, causing the sensor to see the door open, launching the alarm after 30 seconds (with a simulated sensor)
Is there a way to address those kind of false opening, where the door open and then close 1 second after ?
Can you explain what Alarm system you are using. Is this simply SHM, or is the the ADT Panel. There are also several other integrations that could possibly be involved.
how much sway does the door have. Every door/windows sensor I have used has a little tollerance albiet small amount where the door could move before it is triggered. It could be as simple as to replace the door sensor with somethnig that has a little bit more forgivness.
