Will it work with my existing philips dynalite
It discovers by ethernet, and when I had a v1 hub I had to use my public IP. On v2 it is the local 192.168…
Hope it works out, and do let me know any feedback, I didn’t write the handler, but did amend so any improvements can be looked at
metadata {
	definition (name: "Dynalite Dimmer PS1", namespace: "smartthings", author: "Derek Wright") {
		capability "Switch Level"
		capability "Actuator"
		capability "Switch"
		capability "Refresh"
		capability "Sensor"
    preferences {
  	section("IP Address Settings") {
        input "IPAddress", "string", title:"IP Address", description: "IP Address of gateway", required: true
		input "IPPort", "string", title:"Port", description: "Port", required: true
    section("Dynet Settings") {
        input "DynetArea", "number", title:"Area", description: "Area of channel", required: true
		input "DynetChannel", "number", title:"Channel", description: "Channel Number", required: true
        input "DynetFade", "number", title:"Fade Time", description: "Fade time ms", required: true
	simulator {
		// status messages
	tiles(scale: 2) {
		multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
			tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
				attributeState "on", label:'${name}', action:"switch.off", icon:"st.lights.philips.hue-single", backgroundColor:"#79b821"
				attributeState "off", label:'${name}', action:"switch.on", icon:"st.lights.philips.hue-single", backgroundColor:"#ffffff"
			tileAttribute ("device.level", key: "SLIDER_CONTROL") {
				attributeState "level", action:"switch level.setLevel"
		standardTile("refresh", "device.power", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
			state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
		main "switch"
		details(["switch","refresh"])
// Parse incoming device messages to generate events
	log.debug "Parse description $description"
def parseDescriptionAsMap(description) {
	(description - "read attr - ").split(",").inject([:]) { map, param ->
		def nameAndValue = param.split(":")
		map += [(nameAndValue[0].trim()):nameAndValue[1].trim()]
// Commands to device
def on() {
	sendEvent(name: "switch", value: "on")
	sendpreset(3,1);
def off() {
	sendEvent(name: "switch", value: "off")
	sendpreset(3,4);
private getIPAddress() {
	settings.IPAddress
def setLevel(value) {
	log.trace "setLevel($value)"
    //this updates the level of the icon
	sendEvent(name: "level", value: value)
    if(value > 0){
    }else{
    sendchannellevel(3, 1, value);
def sendpreset(area, preset){
 		def ipaddress = settings.IPAddress + ":" + settings.IPPort;
    	def path = "/SetDyNet.cgi?a=" + settings.DynetArea + "&c=255&p=" + preset + "&f=" + settings.DynetFade
		def hubAction = new physicalgraph.device.HubAction(
		method: "GET",
		path: path,
		headers: [HOST:ipaddress],
def sendchannellevel(area, channel, level){
    def path = "/SetDyNet.cgi?a=" + settings.DynetArea + "&c=" + settings.DynetChannel + "&l=" + level + "&f=" + settings.DynetFade
		method: "GET",
		path: path,
def getchannellevel(area, channel, level){
    def path = "/GetDyNet.cgi?a=" + settings.DynetArea + "&c=" + settings.DynetChannel + "&f=" + settings.DynetFade
		method: "GET",
		path: path,
def refresh() {
