Will D-link camera from US be supported by a UK ST Hub 2.0
Hello…
As in the title, My question is about if there is different between D-link cams in the US and UK…
I assume d-link baisd on IP connection rather then z wave or zigbi… So would not be any problems if i use US cam with UK ST hub… Am I Right?
My second question is that, if I link the D-link cam wil I be able to continue using the D-link platform (the app and the recording device) ?
Thank you.
It’s based on wifi so it should work, the only issue would be the power supply being for a US socket.
is not different between D-link cams in the US and UK.
cloud to cloud method connect.
you can use the D-link platform as second app on smartphone
:sunglasses:
Sounds perfect thank you guys…
